  • Replies 127
Posted Images
nice photos guys, just a reminder, if you want them in the calendar, they MUST be emailed through to flick for her to take off to the calendar people. Attaching them here does reduce quality, the forum automatically does that.
Weezy, your photos look awesome, so send them through.
I'll give you some this time flick. car will be looking nice with the paint job. Have to wait until its out of the shop until i can take some photo's.
Can someone here come take some photo's of my car. my photo skills aren't that good and i don't have a good camera.If u can just send me a PM
Thanks
weezy, I got your pm, but PLEASE, email them to me. Even attatching them into a pm or uploading them to photobucket reduces the quality a bit. I know im sounding and being very fusy, sorry, but there is a reason for this - I am being very particular this year with photos, and only taking the best of the best.. Even though last years calendars were great, the limited photos I got, I had to use some reduced quality photos and once they are enlarged for print - they didnt look the greatest. I want this years calendar to be even better than last years.. so im being fussy on photos.
I want this years main photos to be of different members, last years submissions can still be included as a small photo, but if need be, I will make them the main page if their photos are better than others.
So in sounding like a broken record, EMAIL or DVD only!
I want to get this done and dusted by end of next month, so send send send!
Anthony, I had a sms from you guys regarding addy for last years, so as an appology, You will get one of this years copies for FREE. I got a new phone just after that sms and lost all date and totally forgot to sms again to get ur addy, again. SORRY :S
Thanks
same - flick whens the cut-off ? I still have some minor work to be done, and then I got the show in loxton in the next fortnight...
would ideally like to submit my photos in 4 weeks if thats ok ?
-D
Edit - Sample pic with cameraphone after paint job and caliper rebuild, and a couple drunken minutes of photoshopping
Cut Off will be 2nd week of november - so you all have a few more weeks to get me photos. Im a little surprised at the little amount of photos ive had submitted, or the quality of some.
DamageInc, I like that photo, can you get me a good copy of it?
Also, can someone make this thread a sticky at the top? so it doesnt get lost and reminds people to get me photos!
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
