hey guys, just after some quick help, im up for spending some money on my rb25 in an r34 skyline gtt. i have done the splitfires, exhaust, boost controller, and now im stuck for what to do next.
if anyone can give me a general guide/ an order of next mods, that would be wonderfull.
https://www.sau.com.au/forums/topic/282803-next/
rip it out.
chuck in a r33 rb25det and forge it.
neo's can be difficult to work on.
but if u only want 350ish hp, grab a power fc, clutch, injectors, gt35r, wastegate, FMIC, new dump pipe/hi mount manifold, tune, plazmaman plenum and your laughing.
thats pretty mild tho.
forge a r33 rb engine ;):(
Edited by r33cruiser
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761061
rip it out.
forge a r33 rb engine :):D
Oh wow, I didn't realise that the suggestions had to be reasonable, or within a budget
In that case, what you should do, is rip the engine out and mid/rear mount a Rolls-Royce/Snecma Olympus 593 jet engine into the car.
As we all know, neo engines can be quite tricky to work on, and aftermarket parts aren't always that easy to find, i thought it would be far easier to bypass all that and just slot a Concorde engine into your skyline.
Some minor body modfications may also have to be done due to the dimensions of the engine being 4 metres long and 1.2 metres in diameter.
It's all worth it though as you will have 31,500 lbs of thurst at your disposal. That's without engaging afterburners, but we all know afterburners are for fags...
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761397
:D I rate this post lol
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761468
Yeah you could do mad skids with that....
But seriously.
KKR turbo, new dump.
PFC
Pod and cold air induction.
FMIC.
fuel pump
fuel reg
tune it!!!
Don't even worry about injectors, you don't them to get 350bhp, just get them cleaned.
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761642
Will it break traction in 2nd?
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761877
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
