I'm looking for work, the job I've got is taking me nowhere but backwards. I want to start an apprenticeship, something in the auto industry.
Eletrical, Trim, Paint or Panel, in that order, not really keen on mechanical. I check ApprentiCentre and Seek atleast once a day, which is sad.
Does anybody know of any apprenticeships for those trades, willing to take on a 20 year old, with a 2-4 week start ?
The closer to Midland, the better.
I know, until I hit 21 and adult wages it'll hurt, but thats a sacrifice I'm willing to make. $300 per week for 1 year isnt too bad, its not like I have anything to piss that money up on apart from my cars anyway.
If so, PM would be much appreciated.
or, email is [email protected], mobile is 0431 598 320.
Cheers
Nic
https://www.sau.com.au/forums/topic/283009-thinking-about-an-apprenticeship/
hey man, just some insight, if you have the smarts try going for an electrical apprenticeship, if you enjoy it there are hundreds of fields you can take and it generally pays better in the long run, im a first year on 500 a week so it should hurt you too much :huh: and i know alot of apprentices that are above you age so just show interest and you'll nail one :P
just found this...
To be entitled to an adult rate of pay an apprentice must be of the specified adult age at commencement of the apprenticeship. An apprentice who becomes an adult during the course of their apprenticeship shall not become entitled to applicable adult rates of pay
just found this...
Not all companies will follow that. A guy at my work was on $9 as a first yr then we all got a raise and he also turned 21 at the same time ended up on 9 one week and 25 the next.
Apprentices get paid pretty well I think. a 4th year at a good company will be on only slightly less than a tradesman.
tbh i've been thinking the same thing...
im 22 now and pondering going into automotive (in same way or form...)
basically got cert 3 and 4 in IT and half my diploma (bit bored of IT..) working in the mines but soon to be let go due to end of contract..and i want something to do with cars seeming as i <3 my car to death and want more to do with it lol if the starting wage for an adult is like 35k or something (or MORE?!) id be up for it haha.. besides...can you get worse than working 2 weeks on 1 week off 6am > 6pm in summer in the outback? lol
interesting though i didnt realise you could go to an adults wage and stuff...hrmmmm
5 till 8, in summer, with no air con... I would've died to have worked on the mines, but no, had to be a farmer's son lol...
A janitor aside, farming by far one of the most shocking jobs going around... Hence why I moved to Perth! :P
If You do look for an apprenticeship. Try the bigger and well known companies as they usually offer good wages and better working conditions.
I'm a 2nd year electrical apprentice, I really don't do much a lot of the time and I have very little responsibility :P
i looked into this a while ago, wageline say adult wage is min $460 before tax a week last time i called, but they said depends on the employer and obviously overtime and stuff. also think there may be some gov incentives to, but didnt look into that to far.
i know range ford are looking for apprentices atm, and they tend to favor mature age a bit from what ive heard.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
