I will have either, anyone complying these yet? I just talked the missus into the black one. :)
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4765299
HA! That wouldn't have taken much!! :mrt:
no compliance yet!!
but i believe there are a few dealers attempting to......... personally i cant wait, but i really like my turbo AWD!!
You would trade your turbo AWD for a N/A RWD?
What is with the NM35 front though?
think the Pm35 350s is MUCH nicer (that front bar is awesome).
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4765359
Can someone please tell me where I get one of those GRILLS from?
And I'd have the black one any day! looks hot!
cheers
You will need to buy the Axis front bar as well.
The grills are drop much further down the front bar.
You will notice that they are under the line of the headlights, whereas your RS/RX/ARX grill follows the lower line of your headlights.
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4766273
Ok, Cool, cheers for the info, any idea where i can that from as well?
:P
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4766286
:P
plenty go through Yahoo Auctions.
Best pricing for front bars is via Import Monster.
Here is one currently for sale (ands in 6 hours) linky
Edited by iamhe77
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4766335
welll to do the front conversion
u need!
the bar + grille+ lights if u want the S2 lights
but u dont need it if ur going to keep your S1 lights
i prefer the S2 lights and it'll work better with the HID's as the cut off line for the light is clearer
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4766534
u need!
Actually, that front bar I linked to above requires the NM35 headlights and grill. The PM35 headlights won't fit without some crap looking cutting (they are about 10mm longer and come to more of a point than the rounded NM35 lights).
To go with a PM35 front conversion, you need the following;
PM35 headlights (I have)
PM35 front bar (I have the RX front bar on it's way over already)
Grill (or possible a custom grill - dunno yet).
All AXIS and ARX flares/front/rear bars are interchangeable and are also the same regardless of whether it is NM or PM35.
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4767455
Could you use some expanded alloy mesh for the grill? Or would it look too ricey?
You should do the intercooler while the bar is off too Cam. :thumbsup:
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4767652
You should do the intercooler while the bar is off too Cam. :D
Yeah, I was thinking along those lines... if the mesh was painted black...
No need to worry about intercooler timing. The front bar has come off 4 or the last 5 weekends.
Got it down to about 5mins (including undertray) :thumbsup:
Edited by iamhe77
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4767714
So, you free next week? I need to fit the catch can and trans cooler and it sounds like youre a gun. :D
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4767797
It'll be awesome if (or, more hopefully, when) we can get manual M35s here, even if they are non-turbo.
I don't see myself selling my C34 for ages yet, but a black 350S would be a lovely car, I'm guessing...
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4767865
So, you free next week? I need to fit the catch can and trans cooler and it sounds like youre a gun. :P
I may well be free... smart arse
Black 350s would be very nice.
Wonder if it could be converted to AWD
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4767902
I still think ours would be a better base. If I wanted a fast rear drive I would have just bought an XR6 turbo. (let the flaming begin.)
I was just told how much the auto rebuild is going to cost, I recon I should have just slipped a manual in there. :P
https://www.sau.com.au/forums/topic/283184-m35-manuals/#findComment-4767912
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
