For sale is my 1989 r32 gtr. As per my parts sale thread http://www.skylinesaustralia.com/forums/Fi...99#entry4751199 i'm selling up and moving on.
I bought the car in mid 2006 from a forum user in Newcastle. It was stock std when i drove it home to qld. Two weeks later it spun a big end and i then started to create my interpretation of a monster street/drag gtr.
The car has had the engine bay completely stripped back and repainted in a custom purple pearl mix. Every nut/bolt was replaced with stainless. The interior has been completely stripped, all the sound deadening material removed and the floor cleaned spotless.
The boot and rear firewall have been modified as per the pics below. I had the boot setup to take a 20gal RCI fuel cell, 3gal peterson dry sump tank, a nitrous system and a custom fuel system. The rear firewall was completely removed and a new stronger section put in. With the new firewall, i had it made rearward of the shockie towers to allow the rollcage much easier placement. With the boot modifications, the rear boot hinge components have been removed, so pins/locks will need to be installed to mount the boot. This new work has a coat of yellow (not my choice of colour :P) killrust sprayed over the top so it doesnt rust. All this work has been done in accordance with an engineer so the car can still be street registered.
All of the glass/windows were removed in anticipation of getting a roll cage fitted. I still have all the framework and glass etc to go with the car.
The car has also had the battery relocated to the boot. It's also got a lockbar installed and the complete hicas system has been removed. The std fuel lines were removed and theres currently a single -8 alloy fuel line under the car, i've got a roll of the tubing here that can go with the car also to run the other line. It's also go a new set of nismo braided brake lines front and rear. I had the wheels refurbed (lips machined and 2 repainted) at Wheel Revolution in slacks creek around 2yrs ago aswell.
The body on the car is pristine minus the odd little scratch on the front quarter panels & a bit of white paint? on the passenger front guard above the wheel arch (stinking workshops). There are a few spots on the floorpan that have some rust but can be easily cutout and replaced.
It comes complete with all the drivetrain, gearbox, all shafts etc. Full interior minus front seats and aircon. Parts missing to finish it/get it running are listed below.
The car is complete minus the following:
- Complete engine (i have a sump but has had the base cutout)
- Radiator
- Intercooler
- Front bar
- Bonnet
- Front seats
- Air conditioning/heater (dash harness has also had the aircon wires removed)
- Abs (new front lines have been made but will need to be remade in stainless)
- Fuel system
- Clutch line
- plus any other little things i've forgotten
Price i'm chasing is around $7000 as it is and the buyer takes all the spares separately, or $8000 with the interior but back in and all the glass reinstalled. I can also turn the car into a running example with engine and fuel system etc if required also, PM me if you have an option you'd like to discuss. The car is located in Ipswich, Qld.
  • 3 weeks later...
  • 8 months later...
Price drop to $5500.
Have also re-painted the shitty yellow the workshop did on the boot section with gloss black, actually looks half alright now.
  • 2 months later...
  • 2 months later...
  • 1 month later...
  • 1 month later...
shane,
will you sell small bits n pieces? shoot me an email if you decide to. need a few things for mine.
  • 3 weeks later...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
