so the next upgrade i want to do is a lightweight pulley kit, some of the kits available are underdriven, by like 10 and 30 percent for the water pump and alternator
obviously these underdriven kits are for high reving motors , like drift cars right, slowing down how fast the water pump pumps and the charging rate of the alternator... so would an underdriven kit be a bad thing for a motor that isnt commonly in a higher rev range?? although sumday i am planning to drive it as a weekend track car...
Edited by AYW550
https://www.sau.com.au/forums/topic/283268-underdriven-pulleys/
for a daily i think itd be best to keep the stock pulley arrangement. nothing worse than having a flat battery every second morning cos the alternator isnt charging as much as it could. plus youd get no real benefit unless you hit the rev limiter every time you do the groceries
as far as i know, your alternator puts out maximum voltage at fairly low rpms. it doesn't charge any more at 2000rpm compared to 6000rmp. same as your water pump. alot of the v8 boys are putting in under driven pulleys with good results.
yeah as was said, unless you are chasing every last possible pony from your motor and have done everything else, don't bother. spend the money on something more worth while that will give you better gains.
hmmm, well i am chasing every possible bit of power i can from my motor, and have now done most of the NA upgrades possible to my r34 without cracking the motor open, the light weight pulley kits advertise 4-7kw more from the motor plus making it more responsive...but a good number of the kits are under driven and was wondering about the side effects
also, does any one know the dimensions of a rb25de crank shaft and crank pulley? im looking for a single belt crank pully set up, im hoping to greatly reduce the rotating mass of the crank pulley as i have removed my AC system and am planning to replace the stock belt driven fan with an electric fan but havent seen any kits with a single belt crank pulley, anyone know of any? could a crank pulley for a different type motor fit on ? id like to avoid the price of the custom route...
just out of curiousity, what mods do you currently have?
well,,,ive done
-wheels and suspension
-romoved entire AC system (to reduce some weight and gain a bit of power)
-battery moved to the boot (improved handling)
-full 2.5 inch exhaust system with high flow cat, high flow exhaust and coby extractors
-POD filter with heat shield and CAI
will do brakes some other day and replace them with slotted ones when the stock discs wear out, but for now they stop me plenty good
that about it really as far as performance mods are concerned....about to put in new coils and plugs, and soon after that swap out stock radiator fan for an electric one as i mentioned above
so, what do you think?
you should dyno your car and get a tune, would be interested to see wha kind of power an na r34 makes
yeah im keen as to get it dyno tested and tuned, after i get my coils in and the probably the pulley kit ill do it for sure, its also a manual but is 4wd, ive tried to remove as much weight from her as possible too...
:no: 4-7 kw gain, what was that that just flew past my window --why it was a pig--honest :huh: .
;) It'll look good if you get the anodised ones and red will deffinately give the biggest gains, ah-hem :P .
have you experinced cases where light weight pullies made no difference?? reducing the rotating mass of a motor would decrease its work load, requiring less power to turn its self, they say its a similar effect to that of a light weight flywheel, im not saying i believe their claims hands down, but it makes sense to me...
Edited by AYW550
i would be looking at cams over the pulley set. even without an ecu you are going to see decent gains throughout the rev range. look up prices for a set of poncams
ok ill look into that, i had just assumed cams would be expensive
<br />but they are garanteed to give you decent gains. pulleys, not so much.<br />
<br /><br /><br />
yeah true, ill deffinately look into it, i know sumday ill be opening the motor up and i think cams will be the first thing i do,,,would a power fc computer go well with a cam?
Edited by AYW550
Mate , I'm probably being a bit silly there so sorry but yes to you're question , my last but one 00 WRX, had a reasonable amount of mods so was on and of the dyno a fair bit, it had 178kws at all 4 put on a set of lightwieght pulleys just prior to a ECUtech customtune and it read exactly the same as the previous reading with stock ones.
They have a pretty good effect on VG30DE's, normally good for 10-15hp on one of them. Standard pulley weighs around 7kg!
I always thought that non harmonic balanced pulleys where no good on RB's, they have trouble due to the long cranks, it reaches a natural frequency that fatigues the crank then it snaps. Only what I have heard :thumbsup:
<br />They have a pretty good effect on VG30DE's, normally good for 10-15hp on one of them. Standard pulley weighs around 7kg! <br /><br />I always thought that non harmonic balanced pulleys where no good on RB's, they have trouble due to the long cranks, it reaches a natural frequency that fatigues the crank then it snaps. Only what I have heard <img src="http://www.skylinesaustralia.com/forums/style_emoticons/default/wink.gif" style="vertical-align:middle" emoid=":thumbsup:" border="0" alt="wink.gif" /><br />
<br /><br /><br />
hmmm, well i dont like the sound of that...no pun intended!
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
    • HUMVEE are fine in big open areas, but they are problematic on the street and tight areas As for reliability, some of the  US Army guys I have chatted with have said that when they were working they were fine, but, the do spend alot of time in workshops for multiple reasons, admittedly, they did get a hard time by the boys and girls who drove them I would definitely put them in the "buyer beware" category  They do look tough as nails though
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
