Hey all! for the past couple months I've been experiencing rough idle only on start up. It's weird cos it only does it on a warm start, say if I were to turn off the car then start it up 20 minutes later. The idle fluctuates so much to the point of the car almost stalling on me which is driving me crazy :huh: but as soon as I take off and go for a drive its fine. I'll go through and list everything that I've done to try solve the problem.
. cleaned aac valve
. swapped afm with a known working one
. replaced o2 sensor
. checked spark plugs and coil packs
. replaced almost every hose in the damn car so it can't possibly be a hose
. took off my atmo bov and put the stock one back on.
. adjusted the idle (it sits at about 750-800rpm but still has the same problem)
One of the only things I haven't replaced is the fuel pump or injectors. Could it have something to do with the fuel delivery? If someone has experienced this before please help me lol
https://www.sau.com.au/forums/topic/283450-rough-idleout-of-ideas/
My guess would be that one of your injectors is sticking. Maybe run some injector cleaner through your car you can get a bottle from super cheap auto for 5 dollars. I don't think its the pump because if it was the pump you car probably would stall. Could also be the fuel filter. I've also heard of similar issue with people who have a leak in their manifolds, but I don't think this your problem since it goes away when the car warms up. I'd pull out the injectors and give them a good clean.
It shouldn't be the fuel filter as I replaced that about a month ago. But I'll try get the injectors cleaned. Thanks for that man!
my car does the same thing. i was presuming it is a sensor that isnt working until a certain heat. i notice it happens once the autochoke turns off. as far as i know mine has stock ecu. only mods are filter, exhaust, intercooler, t piece. i have used injector cleaners. cleaned maf.
Seems as though a bottle of injector cleaner has fixed my idle issues! :D Just before i filled up today I added half a bottle of the cleaner in and filled up with mobil 8000 instead of the usual vortex98 that I run my car with. So i'm not too sure if it was a combination of the cleaner and different fuel but it's fixed my problem.
Yeah looks like your injectors were getting a bit dirty and sticky.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
