4wd Probs
Just had my car tuned today on a 2 wheel dyno, and now the 4wd light comes on.
Tuner pulled the fuse, so I check it and its ok.
Ecu is flashing 21 times.
Seemed ok on the way home, light came on and i pulled over, turned the car off and on again and it didn't come back on. Went out after and let the car sit for a few hours and when i started it again, light comes on and stays on. Tried pulling the fuse and pulling it back in, light goes off then comes on again, tried switching car off while moving and back on again, same thing light goes away and comes back.
Does the Atessa ecu store codes? Do you have to erase them?
Is it the Atessa ecu flashing or the Main ecu.
If it is the main then you may find it is a error witht the abs sensors due to ony the rear wheels going when on the dyo....
or
Could also be the same for the Atessa ecu...
Try disconnecting the battery then holding ur foot on the break for 30 sec to drain all power reconnect battery and see how you go.
I will dig up the Fault codes for you. Just check the flash sequence again.
Edited by 99 GTT
Here you go mate..
R32 Atessa Codes.
1 Right front wheel speed sensor or circuit
2 Left front wheel speed sensor or circuit
3 Right rear wheel speed sensor or circuit
4 Left rear wheel speed sensor or circuit
5 ABS right front wheel actuator solenoid or circuit
6 ABS front front wheel actuator solenoid or circuit
7 ABS rear wheel actuator solenoid or circuit
8 ABS actuator motor, motor relay or circuit
9 ABS actuator relay or circuit
10 ETS control unit power supply or circuit
11 Fore-and-aft G sensor 1 or circuit
12 Fore-and-aft G sensor 2 or circuit
13 Fore-and-aft G sensor 1, fore-and-aft G sensor 2
14 G sensor power supply 1 or circuit
15 G sensor power supply 2 or circuit
16 Lateral G sensor or circuit
17 Air bleed connector or circuit
18 ETS pressure switch or circuit
19 ETS motor, motor relay or circuit
20 ETS solenoid or circuit
21 Throttle sensor or circuit
22 ETS oil level switch or circuit
Its the ecu in the boot.
Code 21
The only thing i can think of was when the tuner looked over the car he noticed a plug that was unplugged, and he plugged that back in, that and he moved the throttle postion sensor a little.
If i do the batterty discharge thing, will i have to re-set my boost controller?
Cheers
Sounds like your TPS is faulty> I had this on my R33 GTR. Same thing. The light will come on shortly after I start the car. If I Kept driving it wont come on.
If I stopped and idle abit . Boom. on. Changed the TPS after hooking up the NIssan consult.
What sort of boost controller... I would say it would't not lose its settings.... If it did would be no good when you get flat battery....
Someone correct me if i am wrong..
If it comes back on after this then yea the sensor is probley dead...
Part_1_Electrical_troubleshooting_Attessa.zip
Part_2_Electrical_troubleshooting_Attessa.zip
Edited by 99 GTT
 Share
    • Cheers, It must be close enough coz I can’t even tell where u painted. Did u do the whole top of the strut tower or just a patch somewhere?
    • Hey all. Looking for all of the carpeted trunk trim for my 95 GTST coupe. I’m having a hard time finding the pieces I need on US or Japanese sites/auctions and was hoping someone has a clean set stashed away somewhere?
    • New aerial is aerialing well....trips into Goulburn are not losing the ABC classic radio signal Also......I've been procrastinating about wheels for the MX5, the car doesn't need any more tyre, I just "want" different wheels, so I went looking for something that legally fits the new Pilot Sports +1 size 215/45 17 that I'm currently running on the 17x7 OEM wheels (stock size is 205/45 17), not a silver, and not a black, ended up with gloss bronze Konig Dekagrams in 17x8 +40 which fit without the need for rolling the guards, whilst larger than the OEM wheels they are also lighter than the OEM wheels, and at just under $1300 for the set I'm more than happy with the price I seen a set of matt black Deka's on a MX5 when I was at MX5 Mania, same wheel size, same tyre size, sat really nice, and not stretched enough to look aids, although the 215/45 17 is the smallest that you can legally fit Just need to find some good black wheel nuts to suit
    • So I decided that I wasn't happy with how I originally wrapped the loom with fleece tape. I didn't factor in the new intake manifold/plenum so it always sat a bit funny. Yep, I decided to unwrap it and redo how the wires would branch out. Added in a light twist too, here's hoping I didn't snap any 30 year old wiring because FML if I did. Took a few more photos of the shit box too, needed it for Enthusiast Insurance as they wanted photos to justify why my agreed value was above market by a fair amount.
    • if wanting reliability and that level of performance a dry sump is mandatory for circuit stuff as you'll just be filling the head with oil. easy and reliable setup with potential for more later Hypergear bolt on turbo or a g30-660 with T3 rear housing .92 external gate mod to factory exhaust manifold with 45mm waste gate plazmaman/pwr intercooler oil cooler 1200cc injectors 460 TI/walbro with upgrade relay and wiring/pwm control turbosmart fuel reg Link g4x plug in ecu with knock, oil, fuel pressure sensors, 3 port mac valve, DBW conversion Quality clutch kit- NPC is what I've used for a long time READ THE WHOLE OIL CONTROL THREAD Could do major service while there and maybe headgasket, studs and valve springs. as soon as you whack a massive turbo and short runner intake on a street car they are useless and not practical the above will be a fun and reliable 400-430hp on E85 all day with correct maintenance and mechanical sympathy.
