R32 GTR 1989 RACE N SHOW CAR....
BODY: CUSTOM FRONT BAR, AFTERMARKET SIDE SKIRTS AND VIELSIDE REAR BAR
CARBON FIBRE BONNET
ENGINE: MOTOR HAS BEEN FULLY REBUILT
+.040" CP FORGED PISTONS, DUDGEON PINS AND RINGS
NEW NISSAN WATER PUMP
GATES KEVLAR TIMING BELT AND BEARINGS
GENUINE NISSAN GASKET SET
JAPANESE COMPETITION BIG END AND MAIN BEARINGS
TOMEI METAL HEAD GASKET
SET OF HEAVY DUTY ARP ROD BOLTS
STANDARD INJECTORS
STANDARD TURBOS WITH STEEL COMPRESSOR WHEELS AND 360 DEGREE THRUST BEARINGS
TRUST INTERCOLLER
STANDARD AIRFLOW METERS
CUSTOM HI TECH COMPUTER
KAKIMOTO RACING GT EXHAUST
HKS TRIPPLE PLATE CLUTCH
CAR HAS MADE CLOSE TO 300RWKW
MOTOR HAS BEEN REBUILT 7000KMS AGO
INTERIOR: RECARO DRIVERS RACING SEAT
FULL 6 POINT ROLL CAGE PADDED
DEFI GAUGES
7" PIONEER TV TUNER
TURBO TIMER
WHEELS: SIMMONS 18.8.5 FRONTS AND 18.9.5 REARS
CAR IS IN ABSOLUTLY IMMACULATE CONDITION... MAY CONSIDER TRADES..... 0411781754
PRICE: $32000
Edited by GTRBRO
https://www.sau.com.au/forums/topic/283742-gtr-32-race-and-show-car/
I'm in the market but too pricey for me, sorry. Check out the the other GTR's advertised in here and on carsales. You may realise your pricing could be out...by a fair bit. Its a tough market. Also the timing belt looks a lot older than 7K's . Might pay to check if it was actually replaced with the rebuild? . Also might need to put proper turbo's,rods,injectors/pump/reg on it if its going to be a race car. Thumbs up for the cool blue rollcage foam and polish job in the engine bay!
G.L
open to offers, mate i can turn my car into a nine sec machine by nxt week, got 700cc inj, twin 30/35 hks turbo kit, want to sell it like this coz not many ppl like to buy highly performance cars... need it gone as iam off soon...
Edited by GTRBRO
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
