whtbox Posted September 3, 2009 Share Posted September 3, 2009 from what i heard that's how Nissan Dealer do their Transmission service. Even when i call the dealer here they said you probably only need 1 as they just drain from the pan and you won't be able to get all the oil left in Torque converter. Link to comment https://www.sau.com.au/forums/topic/283798-5-speed-auto-oil-change/page/2/#findComment-4806622 Share on other sites More sharing options...
nobby Posted December 4, 2014 Share Posted December 4, 2014 (edited) Hi, recently purchased 2006 v35 with a 5spd auto. Always do my own oil changes etc,but never owned an auto before. After some advice,tips etc on how best to do the auto trans oil My local Nissan dealer wants $60 for 5 lts, of matic J not bad!. After reading post it seems I need 10.3lts. I plan to drain trans,then remove pan inspect clean and replace. But not sure how much oil I'm going to need on hand. I haven't looked yet, but talking with others it seems there is no refill plug,is this correct?. should I drain etc and refill through dipstick tube?. Any and all advise welcome, you can never not know enough. Edited December 4, 2014 by nobby Link to comment https://www.sau.com.au/forums/topic/283798-5-speed-auto-oil-change/page/2/#findComment-7437639 Share on other sites More sharing options...
sonicii Posted December 5, 2014 Share Posted December 5, 2014 As far as I know.. all Auto transmissions are filled via the dipstick tube. Just dropping the pan and re-filling will only replace about half of the fluid in the transmission, so a 5L container will be close to all you need. The rest of the fluid will be sitting in the torque converter, with some in the valve body and cooler lines. A pan drain/refill is fine if you do regular changes as it keeps the fluid fairly fresh. But if it hasn't had a fluid change for 100,000km or so, you might want to consider doing a full flush To do a full fluid change, you will need 10+L and you will either need to take it to a transmission shop, who will have the equipment to do it. or use one of the 'DYI' methods by removing the cooler return lines. Link to comment https://www.sau.com.au/forums/topic/283798-5-speed-auto-oil-change/page/2/#findComment-7437708 Share on other sites More sharing options...
nobby Posted December 5, 2014 Share Posted December 5, 2014 Thanks for the info. just put car on ramps and dropped the oil. so far only 4+L has come out, typical burnt smell. HUmm I'd like to drop alot more if possible. "the good oil" on how to at home please. Link to comment https://www.sau.com.au/forums/topic/283798-5-speed-auto-oil-change/page/2/#findComment-7438017 Share on other sites More sharing options...
sonicii Posted December 5, 2014 Share Posted December 5, 2014 There is a procedure here. http://www.freshalloy.com/archive/index.php/t-149714.html But I would just run the car in short bursts with the cooler line disconnected and then top up the transmission in between, rather than hoping you can 'keep up', while the fluid gets pumped out with a running engine. Also allows you to shift through the gears while the engine is running to ensure the valve body is flushed more thoroughly. Link to comment https://www.sau.com.au/forums/topic/283798-5-speed-auto-oil-change/page/2/#findComment-7438059 Share on other sites More sharing options...
nobby Posted December 5, 2014 Share Posted December 5, 2014 There is a procedure here. http://www.freshalloy.com/archive/index.php/t-149714.html But I would just run the car in short bursts with the cooler line disconnected and then top up the transmission in between, rather than hoping you can 'keep up', while the fluid gets pumped out with a running engine. Also allows you to shift through the gears while the engine is running to ensure the valve body is flushed more thoroughly. Thankyou for the info and link to further info. will tackle it in the AM. cheers Link to comment https://www.sau.com.au/forums/topic/283798-5-speed-auto-oil-change/page/2/#findComment-7438107 Share on other sites More sharing options...
2002stagea111 Posted December 26, 2014 Share Posted December 26, 2014 hello every one, my 2002 stagea 250rs Four (VQ25DD) 5spd auto....just got a freash wof and and service the other day., shes rather mature at 173000kms on the clock but Going Great !!! just replaced the standard oil with full synthetic 0-40 yesterday 5l of new juice and took her out for a drive to auckland today clocked over another 500kms and she was still begging for more seems the change to full synthetic has benefited the car greatly with fuel economy and power., but maybe some people have other thoughts ., in my opinon full synthetic all the way Link to comment https://www.sau.com.au/forums/topic/283798-5-speed-auto-oil-change/page/2/#findComment-7450953 Share on other sites More sharing options...
