For Sale
R32 GTS-4 4 Door Sedan
R32 Spec RB25 DE-T
hks gt2835 pro-s turbo
550cc power enterprise injectors
VIPEC ECU
hks short shifter kit
Tomei Cams
Oil cooler
Remote oil Filter
Underbody Bracing
Tein Coilover Suspension
Recaro Seats Front and Passengers side
Fire Extinguisher
Bayside Blue Paint
Wise Rims
HKS FMIC
ABS removed
Two thermo fans (clutch fan removed)
Engine built by Power Garage Testarossa In Japan.
267kw at 15psi
Car will come with standard GTS4 front bar, not the GTR one.
Bad points
Thrust bearing in the gearbox is noisy
Car is throwing up an ETS pressure switch error on the 4wd System.
Paint work isn't the best.
I am currently clearing a defect on the car.
Car is not engineered.
Looking for around 18k for the car. I am not in a hurry to sell, and may even keep the car. Any questions let me know.
slightly old engine pic
Have probably forgotten some stuff. But thats most of it I think
https://www.sau.com.au/forums/topic/283810-r32-gts4-4-door/
i dunno about the price might be a bit steep.
i only got 16k for mine but its certainly looks like a reliable package.
ha, your not bad are ya? pretty quick to offer opinions on other peoples cars and after the song and dance about your car been legit it wasn't even rego'd with a 25. just let people sell there cars for whatever they want, gl luck with the sale mate, looks good
https://www.sau.com.au/forums/topic/283810-r32-gts4-4-door/#findComment-4774749
bumpski, still clearing defect, car has leaking right rear shock, which I am in the process of fixing.
Also forgot, it also has an r32 GTR fuel pump
Like I said open to offers.
https://www.sau.com.au/forums/topic/283810-r32-gts4-4-door/#findComment-4785319
  • 3 weeks later...
  • 1 month later...
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
