well....that video looks crazy but in fact those g forces are what we are putting through these motors on the race track. and with a wet sump
its a great example of how extreme things really are.
RB N1 vs stock SR20,
both outer pump gears are identical in OD,
pump drive on the SR20 is about 3mm smaller than the RB, which means the actual inner pump gear on the SR20 is 3mm more beefy, probably why it doesnt crack...
SR20 has a 2mm narrower gear due to reduced oil volume needed.
And its got nothing to do with power, there are RB N1's failing 150-200wkw earlier than SR20's running stock pumps.
argh... that sucks about the N1 oil pump. I'm also running one on my GTR, which I think I'll change to a Nitto pump at some point, hopefully soon.
PS: Hi! from a fellow South African :D
If we only had the factory dry sump with this kind of testing...
what a great find - thanks for sharing!
2 q's:
- does the 09 porsche have a dry sump from factory or is this a race spec engine?
- how do they simulate the torque in those gear changes? it sounds like its running through each gear around a track (some type of dyno?)
awesome stuff :down:
2 q's:
Factory dry sump as most 911's have been
It is on a moving engine dyno
PS: Hi! from a fellow South African ;)
Where from?
My advise, change the pump before it breaks... seems to be more a case of "when" rather than "if".
2 q's:
awesome stuff :D
Yep factory dry sump on all ...
And the dyno loads the engine accordingly to simulate the loads/throttle that would be applied when in that particular gear around the circuit...& the fact that they can couple it to simulate cornering g forces as well is really cool.
Im also in two minds what to do with the N1 pump that is on my engine..not exactly confidence inspiring.
I think it should be renamed the russian roulette pump ;)
so we need someone to machine up some splined collars and gears for the pump :D
I'm actually at my machinist tomorrow picking up something anyway so i'll discuss it with him and get back with a possible outcome.
I was just re-reading some mags last night before i went to bed, and i noticed in the article on the "700 Hp GTS-T" Cola coloured with carbon bonnet in HPI 102 . At the starts it stated he fitted an N1 oil pump. Just at the end of the article, it says, "As we went to press, we learnt ..blah blah blah ... the oil pump broke in two places !"
Thought id share
Makes you wonder if something has changed in there material composition or tolerances or something. Has anyone who has been racing or building with N1's for years seen this years ago, or was there a time they seemed to be ok...
I think Greg said he used to use them until the recent failure ?? Makes you ask whats changed..??
Gary
I was under the impression that the early N1 pumps were fine (I believe mine is an early one), but it was rumoured that a couple of years ago production moved somewhere else and then lots of breakages started to happen?*
*may or may not be true
On the gears changing, I know there are some companies in China who are producing a lot of powdered metal parts, maybe Nissan started sourcing them from there? Whatever the case, I won't use them any more, or if someone wants to use one, it's their problem if it breaks.
I'm getting some info on the gear splining, should have some news in the next week or so about a billet spline drive gear set to fit the standard housing. I've also been cadding up a new front housing that uses an external pump, probably a single stage petersen one but doesn't get in the way of the accessory drives or anything else.
And Shane, what are you up to now.... i thought you sold all your stuff !
I'm selling up but that doesn't mean i have to stop developing parts :)
A bit of conflict of interest here but i'll update this post when greg gets back to me.
i like that, sounds promising. i'm happy with wet sump so long as the dam oil pump wont break!!! billet splined would be well worth any cost...
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
