Hey Guys.
Was working on my R33 GTS-T Series 2. Put in new plugs. and now the car has never run the same.
I replace the plugs as the car was unstabe under heavy throttle loads.
I put it back together and its running like a WRX.
After this tho....
I bought new CoilPacks, and new plugs again... and gapped them. and changed the fuel filter.
AND it is still running like a shitbucket wrx. tested crank angle sensor and engin compression ratio, and also fuel pressure.
Any Help.
Next step is to have a look at the injectors.
Any suggestions before i take my car to bits?????
Cheers,
Michael
https://www.sau.com.au/forums/topic/283965-skyline-sounds-like-a-wrx/
yeah will do..
My mechanic mate has put more plugs in and tested them... but will get him to do it again.
So not fuel related.????
Even though it is running lean?
Keep coming with the suggestions :D
It's probably an ignition issue. Try swapping an ignitor with a buddy and see if that works. Also, what are you gaping the plugs to and what kind of coils are you running? Pull the cover off an pull the coil plugs off one at a time. the one that doesn't just about kill the motor and sounds the same is your problem cylinder.
Your car probably isn't actually running lean. If you don't have spark in one cylinder then air and fuel is just passing threw causing the wideband to read lean.
Hope that helps.
yeah will do..
Keep coming with the suggestions :down:
I have had new plugs that where stuffed straight out of the box, quite a few times over the years, but
Try testing the wiring loom for the coils, the loom for these that runs to coils is fairly straight foward to remove from car. I'd bet the loom has poor conections inside it and since you moved this to fit new plugs etc, its proberly upset the ageing factory wiring.
(note) it may test ok, have a look inside loom, I recently did on my gtr and found a real problem as there is a number of wire crimps, which I soldered and my car its now even more of a joy to drive than ever before. If you don't realy know how to solder best to get someone who knows what their doing as these wires are a bit thick at crimped area.
TIP don't just wrap in electrical tape use self alamagating tape, far better sealing properties but expensive. Jaycar have it.
Hope this helps.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
