  • Replies 59
Ref the other Dyno thread.. thats how you convert it.. thats why I said what's shown on the dyno graph probably isn't relative to actual torque.. I think it's some sort of different measurement called "tractive effort".. You'll have to ask our resident dyno operators..
This was the First ever Shootout in Perth in Accredited shootout mode.We updated the weather conditions for every car using the weather station on the wall so your readings were very accurate and any body that thinks the readings were wrong can fax their graph to Dyno Dynamics and they can tell you every thing i did right or wrong by the details on the bottom of the page.
I garranty that this was the most accurate Dyno comp ever in Perth.
Awesome day well organized and run.
Couldnt help notice the two highest readings came from 4 cylinder cars.....hmmmm?(stir stir)
Maybe the six cylinder tractors can compete next time!
Damn I should have turned up :rofl: Just need maybe 1/2 a psi of boost to beat that 344hp :)
was a good day
congrats to john for his 299.5hp with his stock turbo'd soarer (not flowed either) only just beaten in 2.5 litre class by big turbo/external gate equipped r33 which beat him by like 3hp hehe
look forward to the next one
So when do we see the results!?
Yeah do we have a listing of yet of all the winners and power readings? or are we still waiting for the drug test to come through?
P.S Steve thanks for your help the other day! Sly running nicely now!
Will be in the next dyno comp!!
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
