  • Replies 59
Ref the other Dyno thread.. thats how you convert it.. thats why I said what's shown on the dyno graph probably isn't relative to actual torque.. I think it's some sort of different measurement called "tractive effort".. You'll have to ask our resident dyno operators..
This was the First ever Shootout in Perth in Accredited shootout mode.We updated the weather conditions for every car using the weather station on the wall so your readings were very accurate and any body that thinks the readings were wrong can fax their graph to Dyno Dynamics and they can tell you every thing i did right or wrong by the details on the bottom of the page.
I garranty that this was the most accurate Dyno comp ever in Perth.
Awesome day well organized and run.
Couldnt help notice the two highest readings came from 4 cylinder cars.....hmmmm?(stir stir)
Maybe the six cylinder tractors can compete next time!
Damn I should have turned up :rofl: Just need maybe 1/2 a psi of boost to beat that 344hp :)
was a good day
congrats to john for his 299.5hp with his stock turbo'd soarer (not flowed either) only just beaten in 2.5 litre class by big turbo/external gate equipped r33 which beat him by like 3hp hehe
look forward to the next one
So when do we see the results!?
Yeah do we have a listing of yet of all the winners and power readings? or are we still waiting for the drug test to come through?
P.S Steve thanks for your help the other day! Sly running nicely now!
Will be in the next dyno comp!!
    • lol the 2nd one boss, thank you for pointing this out. I feel as i spend more time here this intro message is some thing i will always make me laugh and shake my head at. Perfect Intro:  I have the vehicle
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
