  • Replies 59
Ref the other Dyno thread.. thats how you convert it.. thats why I said what's shown on the dyno graph probably isn't relative to actual torque.. I think it's some sort of different measurement called "tractive effort".. You'll have to ask our resident dyno operators..
This was the First ever Shootout in Perth in Accredited shootout mode.We updated the weather conditions for every car using the weather station on the wall so your readings were very accurate and any body that thinks the readings were wrong can fax their graph to Dyno Dynamics and they can tell you every thing i did right or wrong by the details on the bottom of the page.
I garranty that this was the most accurate Dyno comp ever in Perth.
Awesome day well organized and run.
Couldnt help notice the two highest readings came from 4 cylinder cars.....hmmmm?(stir stir)
Maybe the six cylinder tractors can compete next time!
Damn I should have turned up :rofl: Just need maybe 1/2 a psi of boost to beat that 344hp :)
was a good day
congrats to john for his 299.5hp with his stock turbo'd soarer (not flowed either) only just beaten in 2.5 litre class by big turbo/external gate equipped r33 which beat him by like 3hp hehe
look forward to the next one
So when do we see the results!?
Yeah do we have a listing of yet of all the winners and power readings? or are we still waiting for the drug test to come through?
P.S Steve thanks for your help the other day! Sly running nicely now!
Will be in the next dyno comp!!
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
