  • Replies 716
Posted Images
hahah too late its in a moving box already. also got your ugly mug in some other mag from that dutton years ago.
btw fit the r35 front bar to the shitbox rally car instead of the truck bull bar
  • 3 weeks later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
