Hey people,
Im just after a quick answer to the above question, Im currently running 18psi with standard Internals head gasket. would I be wise to run much more boost later on if I upgrade the turbo or am I asking for trouble without a buit engine and cometic head gasket etc?
I have heard of people running 23odd psi but Im not sure if thats with forgies or standard internals
Mods are:
S2 R33 GTST
Hybrid FMIC
APEXi Super Suction Kit with pod
Custom Air box with CAI(Home Made)
Split Dump and Catco Race Cat
3.5" HKS Cat back Silent High Power exhaust
Exedy 5puk Clutch
Greddy Ex Cam Gear
EMU
Hypergear HighFlow (ATR28 G2 Profile)
Nismo 555 Injectors and Walbro fuel pump
Z32 AFM
Yellow Jacket Coils
Without more info on the turbo, you need to find out the pressure where it starts losing efficiency, or else you're needlessly generating alot more heat than you really be needing to out of the turbos efficiency range.
Ok maybe I should re-phrase my question. We all know that if you rev an unbuilt engine to say 10,000rpm day in and day out it will at some stage let go right?
So does the same thing happen when large amounts of boost is pumped through the same engine?
The max boost my current turbo can run is about 20-25psi but that's not my question.
Let's say hyperthetically I go out and buy X super turbo which has a max efficiency range of say 50psi, now surely if you pump 50psi through a standard internaled engine it will fail as it would revving it to 10k all day.
Does that make make more sense?
Knock levels will be your limiting factor, without lowering your compression or WMI you will get knock.
The combinations that can run more than say 18psi without big knock numbers on a std motor are rare [not impossible]. The more you ask for the worse it will get.
You can wind up the boost, but then you'd have to wind back the timing, so you could be no better off and probably worse than if you hadn't bothered.
But as the others have said - too many worms in the can to say for sure, its not a general rule.
as a very general rule the standard rb25 is reliable for between 250 to 280 rwkw. pick the power you want and choose a turbo to suit. no good having a big laggy turbo for 250 rwkw. if the turbo is sized right for the power and application you want then you only need to run the minimum boost required to get you there.
OP--it sounds as though you think there is a boost number that will pop your motor. There isn't. It's cylinder pressure which if effected by horsepower and knock (and a bunch of other things, but those two pertain to your question.) Like trident mentioned, if it knocks enough, your motor goes pop. Many things can cause knock including to much boost for a given octane of fuel/CR/timing/etc. The other is hp. You try making 1000hp on a motor with stock head bolts, the insane cylinder pressure is going to lift the head and the head gasket will go pop.
Think about how many psi of cylinder pressure you have when the air/fuel mixture goes bang compared to a measly little 30psi of boost. Nothing in comparison. I remember reading a lot of internet "fact" when I first started researching skylines online saying headgaskets go out on RB's at 1.2 bar. Those people had NO clue WTF they were talking about.
Cool that's pretty much what I was after, so long as it's a "safe" tune so to speak there is no majic number.
Thanks for the advice guys.... And not treating me like a dumb dumb, just one of those things I've always been curious about
    • The part where you claim the car "is done" means you won't...
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
