yeh, i kind of know the feeling of sitting in the cabin with the overwhelming scream which you just cant seem to get enough of. Had a little wheel spin moment of my own last outing and spun the engine a little hard lol, i think turning the rpm down is a good idea as they dont like being turned too hard. Still cant imagine the sound of the big cuber at 6200.
Ohh no mate we made the first round! not without issues but we made it. LOL was a laugh considering we only had 2 gear changes per lap due to 3rd gear not working, still finished 7th out of 17 so not so bad.
The crew are quite chuffed considering it was only the purchased parts that let us down.
Big old thank you to Steve Bijok and Heltec, Captain Blair Brownlee, Bernard B Bear Mclintock, Julian, Big Fred who has about the most impressive collection of cars i have every heard about and Jon from DXB racing ( who by the way are our competitors with another ACR viper but helped us out more times than i can count in true spirt of club racers ) and the crew from Axis for the body work and for putting up with me grumpin around telling every one to say away while i wired it. ohh and nearly forgot Spence and missus Spence for corrupting Spanna the work shop dog and turning him into a sooky lar lar with their sauage rolls and home made sangers.
And its 8.3 litre and spins to 6200 :-) you would not believe what its like to drive very different to the old girl. Surprisingly it really wants to make more power at the red line, last 2000 rpm it just launches and sitting between the exhausts it sounds like its doing about 19,000 rpm enough to make your ears bleed!
But man are they a tough old engine we broke a piston ring land on the practice before the race meeting it was about 60mm long and 20mm wide and the compression ring due to the intake temp we think as it was stupidly high. But we have changed the entire ducting for radiator discharge so hope that will correct that. But hats off to the old girl we turned the the rpm down to 5600 using 4th and fifth gear and still put it on p4 only 1.5 second off the new calloway corvette. Removed the head to check before the 45 minute race, which was less than an hour from start to finish and it was still hanging in there. And the result you know even as i said with 2 gears and 9 pistons lol.
look out when the sequential gearbox is fitted and we have a true 450 rwhp and 800 odd nm of torque. Then we will play.
  • 2 months later...
  • Replies 68
Posted Images
Been a while since last post but car is again set to run.
We are the support race for the V8 supers in Abu Dharbi on the 19 / 20th
Ran sequential box last time out and what a difference that made. Anyone coming over for that race :-)
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
