Will be good to see some quick 32's around as well, give the R33 boys some competition
Hopefully power up plan stage 2 will commence shortly for mine, although 230rwkw will do me nicely for a RB20
reckon its great work to finally see alot of projects coming to completion, although as with all car stuff, I'm sure they are all a work in progress, good stuff :D
  • Replies 221
yeah joel i have a flywheel off the rb20, have a os tripple going in so its not needed, PM me if your interested
When finished i hope to have the power that these 33s have but with about 200kg less weight to move around
There will be a couple sleeper 300rwkw R32's 'idling' around adelaide soon also.. :D
Problem is I need a stock RB flywheel so Andrew can balance up the RB30.. Think I can find one.. No sir..
I've got one, I'll sell it to you for $5000 if they are that rare :wassup:
What a bunch of R32 floggs! Gotta be wankin yourselves! :thumbdwn:
Thanks for posting that up Matt, go the stock internals:)
Joel, get a twin plate NOW, and balance it complete - you will need it with all that RB30 torque:)
Twin plate = broken RB20 gearbox. :D
But you never know, depends how the prioritys work out if I come in to some more money. 1. Engine, 2. ECU, 3. Turbo, 4. Injectors or Clutch depending, my clutch should hold a decent amount when the front g/box oil seep is fixed.
I hope you don't mind Steve I borrowed your 9kw to add to my lawnmower. Grass won't be growing back for a few wks.
Hey I got ripped too! Lach used my 17psi tune not the 19psi one :) Gimme the 19psi tune you bastards, I need to exploit my strengths over you higher CR stockies hahaha :rofl:
But in all seriousness I agree with Lachlan, it's great to see so many 250-300+rwkw Skylines in Adelaide :) Makes it better for our more modestly power brethren, 'cause now potential traffic light opponents won't be too sure if they're about to get nailed or not :)
And now back to the thread....... talking about ME & MY STUFF :) j/k
I have to give a HUGE thanks to our very own Steve for setting up a damn fine deal! I now have ~35L of ELF LMS fuel in jerry cans sitting here ready for tuning, & then the Nats :D
ELF LMS is 102RON unleaded that was developed as control fuel for LeMans. A number of rally teams use the stuff too. The 102RON doesn't sound like a big deal but it sure packs a lot more oomph than it would seem!
Thanks to Steve I got in contact with Trent from Autobarn Mile End & he gave me 35L of LMS for the grand total of $0 Autobarn are now (or soon will be) selling LMS for ~$6.50L (35L x $6.50 ='s $227 for free - I'm happy:) ). My car will be sporting Autobarn Mile End sponsorship for the nats as a thankyou.
LMS is not cheap, but considering the gains, & how healthy it is for your engine, it's not a bad alternative to Nitrous. A couple of real world examples of how much extra grunt LMS can unlock:
Martin's HPI Soarer went from 288rwkw to 336rwkw from additional timing & boost all possible due to the LMS. The engine showed signs of less heat build up & NO sign of any detonation on the PFC.
The 10sec Morpowa Lancer was able to gain nearly 100kw via tuning on ELF LMS!
*Note* this was info from the engine builder.
The downside to ELF LMS (apart from cost - although not too bad as a once in a while drag/track day) is the massive headspins it was giving me while driving around town with it in the back of the Liberty!
I also have an Apexi wastegate actuator ready to go on. It came off an Apexi AX53B60 kit & although I don't know what bar it's rated at, I have found info from Apexi that confirms it is, "strengthening spring internal organs actuator", so if it doesn't fix my boost drop I can always have it surgically implanted to strengthen my organ :( Once again thanks to Steve for teeing up that deal (didn't cost a cent!)
Last but not least, I "MAY" have a deal on some R34 GT-R seats! Hopefully in ~2-3wks :D
Hey Matt, thanks, but dont thank me, seriously, thank the generosity of those guys who were willing to donate to a good cause.
Trent is a really nice bloke, loves imports, and fortuneately for us, gets the good gear in cos he actually knows what he is doing, unlike so many other auto parts shops around.
So when are you testing the ELF on the lawnmower, you will probably get another 10-15rw out of her yet.
:( Yeah Lach', Steve & I are just stuffing about, but keep the comparo' graphs coming mate, they're excellent.
Steve,
Very true re Trent (& Irish).
I hope you don't mind mate, but I swapped your 9kw for a Niki 650, pretty much a straight swap really :)
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
