No thanks, I don't even know what a fj40 is?
And why do people keep saying keep my wheels, they're not work deep dish rims??
As of today car has new GTR fuel pump, new door trims (perfect nick) and new rear bar.
Cheers
Daniel
FYI.....
this is my FJ40
Thanks
Edited by pauly990
Heya, interested in a swap for a 2002 Holden astra (blue), Low km's. Great family car. $4000 my way? pm me
No thanks mate, I'm not giving my car away.
Cheers
  • 4 weeks later...
okay guys, after quite a few people driving my car (and not knowing how to drive it)..the clutch is now buggered...still drives but is making funny noises...
Will need a new clutch...seen some good ones around on the forums for $200..still drives though.
Also, one boot hinge is stuffed, boot doesn't close properly and is a little out of alignment..I'm sure I can get a spare hinge for nothing.
No time to fix atm, need car gone!
NEW PRICE
$6800..
If I fix it, price will go back up!
And it will soon go onto ebay and carsales, carpoint so if interested see it first.
Cheers
Daniel
Also, no more test drives. I will drive the person in my car.
  • 3 weeks later...
NEW PRICE
$6800..
Cheers
Daniel
Still for sale...drives fine guys, take off point on the clutch is high that's all.. the clutch is not slipping and the noise was the clutch fan hitting on something.
Car can be picked up and driven for ages without changing anything..
  • 2 months later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
