As stated in title, wrecking a 1997 R33 SII Skyline.
The vehicle is black in colour and was a manual.
Most of the interior parts are still available. All panels and headlights on the front of the vehicle has been sold.
PM for any parts required.
Prefer pickup on heavy parts, but don't mind posting smaller trims.
Thanks!
Edited by DRFT33
https://www.sau.com.au/forums/topic/285065-wrecking-1997-r33-sii/
hey mate just wondering if you still have the diff? if so does it have a 2 or 4 bolt rear hat that bolts it to the cradle? if it is 2 bolt which i think it will be would you be keen on selling/swapping just the rear cover, cheers. im in adelaide aswell by the way
Thanks!
Thanks!
disco potatoe - Sorry not seperating any engine parts but depends on what you're after? I have GT3582R turbo, X-Force high mount manifold, Tial 38mm wastegate, 3inch dump and screamer, braided oil and coolant lines for $2200. 80mm throttle body - $150. Let me know what you're after exactly.
pingping - I do have the ashtray. I can send you picture but it just looks like all the other ashtrays? Anyway - $20
Muges180 - As above, if pingping doesn't claim it, then the ashtray is yours for $20. Center console lid - $20
Zoidberg - Front and rear seats available. $150 for the lot. RHF seat has minor stitching come off about 1cm.
lolnic - $150 for all the seats if Zoidberg doesn't want them.
dor180 - Sorry, the locks have been sold.
2FST4U.R33 - handbrake tip available. The grip looks worn though? let me know how much you want to pay for it.
Turk1 - Sorry, front grille is gone.
Craig132 - Front brake calipers and rotors - $250. Rear brakes may have been sold but I will let you know.
codys97 - I'm not sure on the rear diff, I'll need to have a look but it is the VLSD (GTR rear diff) model so might be completely different from what you're after.
Darren33 - Not sure on what you're after buddy.
Bigmikespec, Aberax, Weezy, F9292 - trying to send PMs at the moment - will get one soon.
Hi there, i'm desperately looking for The R33GTS-T Crossmember, RB25DET Rubber Mounts & RB25DET Allumunium Engine Mountings, if you still have it i will take it. Please let me know ASAP. My email: [email protected]
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
