As stated in title, wrecking a 1997 R33 SII Skyline.
The vehicle is black in colour and was a manual.
Most of the interior parts are still available. All panels and headlights on the front of the vehicle has been sold.
PM for any parts required.
Prefer pickup on heavy parts, but don't mind posting smaller trims.
Thanks!
Edited by DRFT33
https://www.sau.com.au/forums/topic/285065-wrecking-1997-r33-sii/
hey mate just wondering if you still have the diff? if so does it have a 2 or 4 bolt rear hat that bolts it to the cradle? if it is 2 bolt which i think it will be would you be keen on selling/swapping just the rear cover, cheers. im in adelaide aswell by the way
Thanks!
Thanks!
disco potatoe - Sorry not seperating any engine parts but depends on what you're after? I have GT3582R turbo, X-Force high mount manifold, Tial 38mm wastegate, 3inch dump and screamer, braided oil and coolant lines for $2200. 80mm throttle body - $150. Let me know what you're after exactly.
pingping - I do have the ashtray. I can send you picture but it just looks like all the other ashtrays? Anyway - $20
Muges180 - As above, if pingping doesn't claim it, then the ashtray is yours for $20. Center console lid - $20
Zoidberg - Front and rear seats available. $150 for the lot. RHF seat has minor stitching come off about 1cm.
lolnic - $150 for all the seats if Zoidberg doesn't want them.
dor180 - Sorry, the locks have been sold.
2FST4U.R33 - handbrake tip available. The grip looks worn though? let me know how much you want to pay for it.
Turk1 - Sorry, front grille is gone.
Craig132 - Front brake calipers and rotors - $250. Rear brakes may have been sold but I will let you know.
codys97 - I'm not sure on the rear diff, I'll need to have a look but it is the VLSD (GTR rear diff) model so might be completely different from what you're after.
Darren33 - Not sure on what you're after buddy.
Bigmikespec, Aberax, Weezy, F9292 - trying to send PMs at the moment - will get one soon.
Hi there, i'm desperately looking for The R33GTS-T Crossmember, RB25DET Rubber Mounts & RB25DET Allumunium Engine Mountings, if you still have it i will take it. Please let me know ASAP. My email: [email protected]
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
