Hi all,
As topic says, and it would be to prefere To an R34GTR, Have one for RX7 and it is diffrent from the R34GTR Japanese manual..
Any kind person ho have one or nowing about where to get a hold of an and just to The R34GTR Plz.
Kindest Regards from Izy Sweden...
Klaus
https://www.sau.com.au/forums/topic/28525-apexi-manual-in-english-wanted/
No this is for an Civic, That i dont needed :cool: I am after the how to install it for an R34GTR same as the one ho come whit the Power Fc, Whitch wire you are cutting and so on so it must be to an R34GTR...
Have none a R34gtr and has mount a Power fc in to ut?
Cheers Klaus
Klaus - you have an R34 GTR now?
damn man, i'm jealous!!! :(:P
Any pics? I bet your car gets lots of looks now!!!
As for the R34GTR Apexi manual, I think you are out of luck, but I know with my Power FC it connected straight into the standard loom, there was no cutting neccassary... Have you tried just plugging it in?
Is there anywhere over there that can tune them?
Christian
damn man, i'm jealous!!! :):P
Christian
Christian... Yes it is correct :( A Lightning Yellow allsow :burnout:
Yes i have some, Shall post them in this thread soon for you to see..
Yes it is so but it is 2cables i must cut to take plus from only in the R34GTR Vspec variant.. Have the Japanese manual so i can se the pics not understand it only :D
Haha it is some few ho can do it but this D Jetro verision im gonna tune self...
Regards Klaus
Klaus what happened to your R32... your beautiful R32... at least u din get an R33 like some ppl :P
best I could find was this...
http://forums.skylinesdownunder.co.nz/show...&threadid=13195
Its vague instructions on how to connect an RSM to a 34. Hope it helps.
Hello, Long time since last =)
That car was sold out when i get a good price for this R34GTR VSPEC from 2000 and it have only travel 17000km, 1700 Swedisch mile =)
Hmmm Miss my R32GTR Aswell :( but she has a new good owner now anyways, Takencare of her.
Yes it was or are, it is in the GTROC 2004 Calendar, Check it up
Kindest Regards Klaus
if that dun work scan the install manual and I'll get my gf to translate it for u lol
It would be weary nice of her / you if you can do so for me...
Drop a mail whit your mail add at ny home mail so i can return the scanning stuff to you.
[email protected]
Cheers and thanx dude =)
Klaus
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
