For now i've got a little bit of extra cash and seeing as my car has no zhaust I was planning on getting one...
Just after some opinions on what I should get and atm i'm only after some sound
I was told by my cousin if I was after noise I should go with a 2 1/4 Catback with a 5" Cannon and remove my mufflers.
What do you reckon?
*edit* Budget - Roughly $500
Edited by Razzle-Dazz
https://www.sau.com.au/forums/topic/285339-zhaust/
a straight pipe from behind the cat with a 5" tip muffler ...... yeah that's pretty loud! The police will hunt you for that.
and won't have much trouble finding you as they will be able to hear you from 3 suburbs away, LOL
the car is a NA. it will need mufflers to be quiet. a turbo on the other hand will be much more quiet with the same system
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4793212
What do you reckon?
Don't do it, the only thing less classy than an underpowered car making a ridiculously loud noise, is an underpowered car making a ridiculously loud noise with a cheap overstated body kit.
BTW you could probably get the desired effect by taking a 1/8" drill to your existing muffler.
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4802250
im running stock headers, then 2.5" piping with a leaking resonator to twin 2" tips. Its not THAT loud....but the noise is definately an aquired taste...
if you want something louder i reckon just replace the rear muffler with a cannon, dont waste money on the rest of the exhaust...
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4806025
What do you reckon?
I reckon just run a pipe off the cat to side-dump under the driver's door. f**k the cannon, that shit muffles things occasionally.
Wind the window down and you'll be sick as.
Cant you READ?, he already said his car does NOT have an exhaust...i would've thought that would be loud enough
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4807109
I can read actually. Can't you? The OP specifically says he wants an exhaust.
So his 2 aims are:
1. loud
2. have an exhaust
Hence why I suggested one to him that doesn't make the car too much quieter than his current un-loud setup. Telling him to leave the car without an exhaust doesn't meet his "I want an exhaust" requirement.
I'd also suggest removing the cat, which will provide even more noise, and hopefully sick flames to boot. The extra bang from flames popping out the exhaust will not only give him "some" sound, but also an "extra" sound to boot. Its a 2-for-1 deal that's only a broom handle away!
No idea why people get smart when I post things.
It helps counter-act the dumb.
Edited by scathing
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4808340
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
