For now i've got a little bit of extra cash and seeing as my car has no zhaust I was planning on getting one...
Just after some opinions on what I should get and atm i'm only after some sound
I was told by my cousin if I was after noise I should go with a 2 1/4 Catback with a 5" Cannon and remove my mufflers.
What do you reckon?
*edit* Budget - Roughly $500
Edited by Razzle-Dazz
https://www.sau.com.au/forums/topic/285339-zhaust/
a straight pipe from behind the cat with a 5" tip muffler ...... yeah that's pretty loud! The police will hunt you for that.
and won't have much trouble finding you as they will be able to hear you from 3 suburbs away, LOL
the car is a NA. it will need mufflers to be quiet. a turbo on the other hand will be much more quiet with the same system
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4793212
What do you reckon?
Don't do it, the only thing less classy than an underpowered car making a ridiculously loud noise, is an underpowered car making a ridiculously loud noise with a cheap overstated body kit.
BTW you could probably get the desired effect by taking a 1/8" drill to your existing muffler.
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4802250
im running stock headers, then 2.5" piping with a leaking resonator to twin 2" tips. Its not THAT loud....but the noise is definately an aquired taste...
if you want something louder i reckon just replace the rear muffler with a cannon, dont waste money on the rest of the exhaust...
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4806025
What do you reckon?
I reckon just run a pipe off the cat to side-dump under the driver's door. f**k the cannon, that shit muffles things occasionally.
Wind the window down and you'll be sick as.
Cant you READ?, he already said his car does NOT have an exhaust...i would've thought that would be loud enough
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4807109
I can read actually. Can't you? The OP specifically says he wants an exhaust.
So his 2 aims are:
1. loud
2. have an exhaust
Hence why I suggested one to him that doesn't make the car too much quieter than his current un-loud setup. Telling him to leave the car without an exhaust doesn't meet his "I want an exhaust" requirement.
I'd also suggest removing the cat, which will provide even more noise, and hopefully sick flames to boot. The extra bang from flames popping out the exhaust will not only give him "some" sound, but also an "extra" sound to boot. Its a 2-for-1 deal that's only a broom handle away!
No idea why people get smart when I post things.
It helps counter-act the dumb.
Edited by scathing
https://www.sau.com.au/forums/topic/285339-zhaust/#findComment-4808340
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
