Hi everyone.
Time to let the rotary go guys. im starting my electrician apprenticeship next year and will need to buy something more usable e.g.vy ute
also open to trades cash my way
down to details:
POWER: 232RWKW 16PSI (240rwkw 17PSI)
TUNER: DALTON AUTOMOTIVES (CHRIS)
PRICE: $14,000 ono
MAKE: MAZDA
MODEL: FC RX7
YEAR: 89'
REGO: DECEMBER 09'
RWC: NEGOTIABLE
contact: PM or 0431324692 (you may need to send sms as i cant always answer the phone)
RECIEPTS OF EVERYTHING WILL BE INCLUDED. E.G. ENGINE REBUILD, TUNE, EVERYTHING!
Engine Modifications:
please note: i spray canned nearly everything in the engine bay black lol (wanted stealth look ill put photo up soon)
-MICROTECH LTX12 (LATEST MICROTECH ECU)
- 4X BRAND NEW BOSCH COIPACKS + new relay system
- NEW LEADS & NEW ECU LOOM
- Brand new bosch 023 600hp intank fuel pump
- 550cc primary and 1700cc secondary indy blues injectors
1> Fully rebuilt engine (AROUND 15K OLD) - rebuilt promaz
2>'Tuff stuff' race seals
3> Heavy duty exedy clutch kit
4> BRAND NEW ATR 45 TURBO WITH TR43 FRONT (480HP RATED)
5> custom oil and water lines
6> stainless steel manifold
8" 2.5" INTAKE PIPE AND POD
9> Knight sport fuel cut defender
10> OIL CATCH CAN
11> Front mount intercooler with custom piping
12> Custom 3" dump - front and cat exhuast & 2.5" catback exhaust
13> front mount oil cooler
14> master and slave clutch and brake cylinder and lines (all reciepts included.)
15> starter motor & relay system
16> resprayed lower intake and upper intake manifold
17> all new vacum hoses, clamps, radiator hoses
18> new exhaust and inlet manifold gaskets and seals.
Suspension:
1> Cusco zero, hieght and camber top adjustable coil overs all round
2> new Solid engine mounts
3> s14 / r33 rims sprayed hyper silver (FRONT)
4> 18" X 10" WIDE +13 OFFSET VS - kf Shadow chrome (REARS)
Interior
1> New 5x mechanical Defi style 60mm gauges
Boost (bar version), air fuel ratio, water temp, oil temp & 10,000rpm gauge. - controlld by switch in cabin
2> aftermarket black steering wheel
3> STANDARD GEAR KNOB
4> drift handbrake button
5> Sunvisor DVD player.
6> brand new jvc headunit mp3 etc.
7> 4" speakers front
8> 6" speakers door cards
9> 300w amp
10> 800w sub + ported box.
11> New GT3 Seat cover front and rear
Exterior
1> Resprayed Jet Black
2> standard original s5 bodykit
3> HOUSE OF KOLOR GOLD PEARL
5> spoiler removed and holes filled.
https://www.sau.com.au/forums/topic/285551-240rwkw-rx7-fc-series-5/
shit question but...how many km's you get out of a tank dude?
I got your msg about the swap, and i love RX7s, but it'll be a daily driver, so dont wanna be spending 100 bux a week on fuel
around 350+kms city driving
450+kms highway
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
