Yes you read right, got a fine and want to get out of it, has anyone done it?
Dont want to hear from people who just want to tell me that i got the fine and now i should live with it, its not that simple in this case (happy to pay the points are the issue).
Also when i got this i was on a 1 point probation, now im off that will the points be back dated and i lose my license if i pay the fine?
If you are on the photo (go down toe civic compliance and see the photo), then you are well... stuffed.
That is why they take photo's as evidence. The only way your are going to get off is if the photo is a bit ambiguous and you can't clearly see your number plate.
I believe the points will date back, and VicRoads will send you a letter
Unfortunately being a truck driver means that i cant afford to have the points taken off see im seeking out other ways, there are websites around that tell you how to do it but dont know any one who has used these successfully.
Only other option is to sign them over to someone else but since it was in a truck does the other person need a truck license, on the fine it says it was in a "vechile other than a heavy vehicle".
What do you mean get around it? You were busted red handed - there is no such "getting around" anything.
You could pass them off onto someone else i guess, illegal however. And i would imagine they would need a truck license as whoever re-processes the form is likely to check (i would imagine).
i tried to get out of a red light fine. even went down and saw the pics of the car going through the lights. they also sent me this other thing which was at least 2 pages long shows 3 pics of my car in different stages from when then lights turned red and at what second i went through it. its hard getting out of man.
think i have it some where. if i find it ill scan it and put it up for ya
If the offence was in a truck then using someone who doesnt have a truck licence may result in them receiving an unlicenced driving sting.
I'm a truck driver also and I have an old guy at work with a HC that doesnt drive anymore that sells them off for a gorilla a piece. Cheap price if the alternative is no work for a month or two....or twelve.
I'd be offering someone at your workplace a bucket of cash for some points.
At worst you can apply to vic roads to be allowed to drive during working hours if you can prove that you will lose your job if you can not drive, willing to pay someone to take them but not for 1k each.
Ok well when i was a little younger, dumber... i got a fine which consisted of 12 month suspension 8 demerits 500 fine etc.... 156 kmph on western ring... neway i got out of it :D
How?
well 1.. lucky to be a photo from behind so they dident see me..
2. dads misses has a medical condition
3. dad sent letters in saying shes psycotic bla bla sent in docters certs and letters from her docter (this docter helped us out)
now they dident care.... they sent bak the infringment notice again and again so my dad craked it sent bak 1 hell of a letter and they neva sent one bak again
Saved my licence :) and for all thoes saying WARE UR PENALTY you cant get out of it in your face :) i got out of it :)
I challenged one in court, was on the edge of the line, in traffic inside the intersection, the argument that I entered on a green light was not good enough.
I got no demerit points after taking it to court but got the fine.
That was ONLY because I had no previous fines, its going to be tough to get out of losing the points :)
hmm is vehicle registered to work?
If so how well do you get along with mgmt?
*could it be that*Company owned vehicles might have so many different drivers that its really impossible to tell who was driving at the time? And can pay an additional payment as well as fine to not nominate driver. To date I am not aware of actual driver logs being cross referenced afaik provided the bastards get their money the rest is who cares.
They normally ask me who i want to sign it over to before they do it but it was a new chick that signed it over, the boss him self is an arse hole and wouldnt go through any extra shit for his drivers.
Its also a company vehicle that is registered in a different company's name.
Also this fine is from december but they have only just signed it over to me last week.
Guest
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
