Hey guys, I'm after your advice. I have a Stagea 260RS with an RB26DETT from an R33 GTR. 2 weeks ago the car just cut out. We found that the ignitor module was dead, so ordered a new one from Nissan for $800! The car ran fine for 2 weeks and then the same thing happened again last night. Not happy! Any idea what might be killing the ignitor module? I pulled out the coil packs and measured the resistance on the primary and they were all around 0.8ohm, which looks good. I checked the grounding, power supply and also checked I was getting a good signal from the ECU and it all looks good. Any ideas? I really don't want to put another ignitor in there and then have it die on me again.
https://www.sau.com.au/forums/topic/285883-car-has-fried-2-ignitor-modules/
Some questions:
How have you diagnosed that the ignitor is "dead"?
Have you substituted a set of known working coils with you ignitor? While you are at it, substitute a known good harness also. Double check the earthing eyelet is both well connected to the harness and is cleanly ground?
I assume you're not running an HKS Twin Spark (or other CDI pack)?
Finally, I don't pay heed to the Nissan manual's method of diagnosing by measuring resistance - I've had failed coils return exactly the same readings as good coils.
PS - there should be some warranty on the ignitor from Nissan.
Bad ground. Check you have at least 2 good grounds from the engine to the chassis. Loosen them off, give them a wiggle and tightten them up again.
A bad earth causes the ignitor to not be able to switch max current to the coils. It can also cause the ignitor to burn out as the earth signal drifts around.
Thanks for the feedback guys. I don't have a set of coilpacks to swap over, but I should be able to get some from my mechanic. When the first ignitor died, he just swapped it over with a known good one, and it all came good. So no need to investigate any further. I was away last week, so just bit the bullet and bought the new one to get the car going for my wife.
I'll take a good look at the earths tomorrow. Might need to look into that Nissan warranty... thanks
My money is on a dodgy coil. Sometimes a newer (i.e. stronger) ignitor will mask a bad coil for a while. Borrow a set of known good coils and see if that makes a difference. If you are still using the original OEM coils it may be time for an upgrade anyway.
Well, I've bitten the bullet and ordered a set of Splitfire coilpacks. If they're not dead already, it's only a matter of time, so I'd may as well replace them now. Fingers crossed this fixes the issue.
  • 1 month later...
Well it's been a bit over a month since I replaced the coils and the car has probably done over 1000km and has been running great. Until today.....
Exactly the same issue. Engine just cut out. I haven't had a look yet, but I'm 99% sure the ignitor module is fried again. Not happy at all!! I have bought 2 ignitors now ($1500), plus a set of Splitfire coil packs and now it looks like I'm up for another ignitor :ermm:
I'm not sure if it's a coincidence, but all 3 times it has died under similar circumstances: cruising down a hill (overrun fuel cut would have kicked in), get to the bottom, go to accelerate and find it is dead. It has a Vipec ECU (has been in there since November/December last year without any problems). I've emailed them already to find out if they have any ideas.
Exactly the same issue. Engine just cut out. I haven't had a look yet, but I'm 99% sure the ignitor module is fried again. Not happy at all!! I have bought 2 ignitors now ($1500), plus a set of Splitfire coil packs and now it looks like I'm up for another ignitor :)
What new wiring has been done in the engine bay/car. Has there been any new sections that were soldered? I had a similar thing happen to me where an electrical short fried my CDI (Autronic) I pulled the coil wiring apart and found a solder joint that had a little peak which rubbed through the wire insulation and bang. Although mine didn't cut out entirely but was running on 2 cylinders.
Have a good look at the wiring- i know it's a pain in the ass but hopefully you can remove the wiring as the cause if you find nothing?
Hope that helps.
Hope that helps.
my bet is the coil loom...these things get very brittle with heat and this hardens the insulation which causes it to flake and expose the conductor. This shorts the output causing extremely high current which frys the power transistors in the igniter.
I spent a fair bit of time going over the loom last time I had this problem. All of the connectors are in good condition. None of them have become brittle yet. I also spent some time measuring for shorts while shaking the loom to see if there were any problems. Very frustrating problem this one...
its not in the connectors...im talking about the coil loom itself. You will not be able too see the damage (if any) unless you remove the grey tape. When you have installed the coils you may have moved the loom around separating the possible damage site. With engine movement the damage has moved close enough to short out again. Ive seen this problem before and it normally occurs at the bend in the loom near coil 5.
not saying this is 100% what it is but id untape the loom and do an inspection.
Edited by DiRTgarage
Well the car is running again. I cut open the ignitor module and found the PCB track to the ground pin had burnt out. I soldered in a piece of wire and it's running again. Who knows how long it will run for..
The question is, why is the ground track on the PCB burning out? This is the only ground for all 6 transistors and it burnt out after number 6, hence I lost all transistors.
OK, as promised here are the pics of the ignitor modules. I owe a thanks to FastRotor who's been offering me advice about this problem.
Bit of a how-to guide:
1. Cut open the box around the top, about 5mm in from the edge. I used a Stanley knife and only managed to cut myself twice :P
2. The inside is filled with this sticky silicone-like clear substance. You can poke your multimeter through it to determine the dead track. You can see my dead track on the top left (it's a bit burnt). This is where the last transistor connects to the ground pin. The current from the emitter on each of the 6 transistors flows through this piece of track.
3. Peal back the sticky sealant.
4. Solder a bit of wire over the broken track. The solder Nissan have used is quite hard and requires a fair bit of heat to melt it. I had my soldering iron set to 400 degrees to melt it.
5. Once you're happy with your wire you can place the sticky sealant back down over the top of it. Be careful of the little silver leads they are very fragile.
Quite an interesting design inside that little box. I've never seen transistors that look like that and definately haven't seen a board covered in that sticky silicone stuff.
So I guess the question now is: what fried that little piece of track.
It's got to be one of 2 reasons:
-Too much current
-More than 2 transistors on at once. The ECU I'm using runs wastespark, so there are 2 transistors on at once. This means twice the current through that track. Heaps of people have run this before, so I doubt it's a problem. However, if for some reason I got a short on the input or an ECU fault, I could potentially switch on 4 or 6 transistors.
-Short across the primary on one coil pack. If I got 12V shorted across the primary then you'd have a short through one of the transistors. Would the single transistor fail instead of the ground link? I've stripped back the loom and it looks OK, the coil packs are brand new, so this doesn't seem like a likely cause. I've also measured the resistance between ground and the battery and it is 0.1ohm, so looks good to me. Unless there's a loose connector somewhere. I tightened the ones I could access last time I had this problem.
-Higher alternator voltage. That combined with wastespark would mean more current. The max voltage I saw today in the logs was 13.87V so that looks OK.
-Too much dwell
-I just went for a drive and had a look at the log. The dwell is sitting at 1.8-1.9ms with a max of 2.7 at some point, so it looks OK. A dodgy CAS might cause the dwell to go high at some point..
-One of the inputs is jammed on for some reason. I guess this could cook the ground track or the transistor or the coilpack. Who knows?
So that's all I can think of. Anyone got any other ideas? I think I'll fix my other broken ignitor and drive around with it in the glove box in case of an emergency. :P
-Too much current
-Too much dwell
dont forget about the base current from the ecu to switch the transistor. This current also goes to ground through that track.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
