Hi all, just seekin info on moddin my V35.
I am torn between buying the rims 1st or go for a "not-too-wild" bodykit.
The main reason I am asking this is that if I put on the kit, will the underside of the car get scrubbed more as I only have 17 inch rims?
Any info would be great as I am new to mod scene.
Thz.
https://www.sau.com.au/forums/topic/286015-1st-mod-rims-or-bodykit/
I'd go for rims first and possibly lower it.
I think its better to get the size of rims that u want on the car, then decide which bodykit will fit them best. you dont wanna have to modify the kit once its already on the car. but yeh, us my opinion.
what size rims u goin for?
Thz for the info Benzino33.
I want to go 19x8.5 at front and 19x9.5 or 10 at rear but not sure of the offsets yet. any opinions with that size? :(
I want to go 19x8.5 at front and 19x9.5 or 10 at rear but not sure of the offsets yet. any opinions with that size? :D
do some reading when it comes to size and offsets, check out photos to see how they sit in the guards
keep in mind if u want to put a wide body kit on after choosing you wheels - you will have fail fitment
and no one likes fail fitment
just remember that legally skylines must have same rim size (diameter & width) front and rear as they came out with same size all round from factory
I thought you had some legal 'waggle room' around the stock total diameter and width?
I'm not sure what it is mind.
I would get some rims first with nice dish on the back :down: Maybe go 19" thin spoked rims then lower it instead of a bodykit.
that's a good point Dani Boi. but do you think i will need a permit for changing the suspension and ride height?
yeah, i've heard that too. but i got my V from fabcar and it already come with different offsets front and rear. that's why.
Don't need a permit, but legally your car is supposed to be at least 100mm from the ground with a full tank of fuel and 5 people in the car.
ok. thz for the info SKYRYAN. so maybe i can lower my car. i can't go all low cuz i got a steep driveway. :down:
any suspension place you might recommend and about how much shall i save up for it?
Bodykits look stupid without the right offset rims especially with stock rims.
Go rims and lower it a bit. Talk to WA suspensions, they are a forum sponsor here.
thz Pattygtst. will contact WA suspensions.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
