hey guys i have a 97 rs4 that i picked up for 9 k , i also have a spare 25 sitting in a mates shed.
What im trying to decide is do i convert my car to manual and build up a forged 25
Or do i go out and buy a autech.
I have already upgraded my sway bars to adjustable whiteline
And i have done a r33 brake conversion.
My rs4 is in realy good condition and alredy has a standard body kit on ( different to most not shaw what it is )
any opinions on this would be great, also if some one has an autech are they much better ???
motor might not have the AWD sump/block. if you have the parts, then why not manual convert, could be fun. I wouldn't go out of the way to spend the money though personally.
An Autech in good condition will cost you around $20k more than you bought your RSFOUR for, and you'd be looking at a relatively stock car, from what I have seen advertised. If you're not after a RB26, my money would be on the conversion: heaps more performance per dollar spent.
Pics of the bodykit, please!!
yeah i was going to use the sump of my car and as for the block there is no difference except for what bolts on
I had also considered using a S2 sequential shift auto , i just think the auto's are to slow to shift.
S2 dont have sequential, its tiptronic, and the shift time even when in tiptronic is pritty average, about the same as the normal auto mode.
DanMcd you hit nail on the head mate thats waht ive been thinking.
Im gonna go to perth soon and take a test drive in a Autech and see if the money is worth it.
To up grade will cost me about 10-14k more than what my Rs4 set me back so i could build one hell of a stagea for that sort of coin.
I wonder if you could get a stage under the 9 sec mark ha ha
Mate im in Bunbury i have a Autech (well a replica but basically a autech) send me a text and i'll take ya for a spin save ya the trip to perth.
26's are awesome and all but very expensive to repair and mod. Comes down to the budget you want to spend.
Talk to Unique. He knows. Ref standard Autech, RB26 @ ~ 214awhp. Well mine was anyways. Probably worth spending some coin if you already have a beast with factory manual setup to start with, depends how keen you are really.
Cheers GW
Yeah second that... it's the upshifts which are the real killer (by which I mean 4th->3rd->2nd etc) - it takes about half a second or more! Also when accelerating, you've gotta select the next gear ahead of time (don't know how - just practice) and this is difficult around redline, where the RB gains revs so fast.
Edited by DaveB
hey mate just make sure that spare rb25 u are gonna build up is from a stagea or it wont have the correct bolt pattern for the awd sump, only the stagea rb25s have both bolt patterns for 2wd and 4wd sumps, where as r33 gtst, etc only have the 2wd bolt pattern.
You can get away with using the r33 rb25 but u will need a 4wd sump adaptor which is about $930 so best to just start with the correct block if you can.
If your gonna bother building up a motor you might as well use a rb30 bottom end i reckon, these heavy cars need all the torque you can get, especially if you upgrade to a decent sized turbo setup. I run a 26/30 with a gt3076r are its great for cruising around, i can go around at 20kmh in 3rd gear without a problem, unlike the old 26 setup and t04z i had.
If it was me i would just buy an autech personally. RS4 stageas have crap diffs, axles, rear cradle isnt good for decent wheel offsets and they are auto, plus brakes are tiny too, so by the time u upgrade to decent suspension, new engine, manual box, bigger brakes, swaybars and then diff, axles you could have an autech and its a hell of alot easier. Things add up soooo quick when doing upgrades you will get a big suprise. At the end of the day if your talking built engines etc then i wouldnt waste my time with a rs4 when there is something available with all the good bits in a factory package. I would like to know why an rb26 cost more to build and modify than a rb25? its actually cheaper, you can use stock rods and bolt on low mount turbos which saves alot of hassles, plus the added bonus of readily available second hand performance bits like injectors and clutches, etc. Rb25s and rb26s still have the same amount of pistons and rods :)
Trust me ive been there and done that along time ago :D
Edited by unique1
I would like to know why an rb26 cost more to build and modify than a rb25? its actually cheaper, you can use stock rods and bolt on low mount turbos which saves alot of hassles, plus the added bonus of readily available second hand performance bits like injectors and clutches, etc. Rb25s and rb26s still have the same amount of pistons and rods :D
I argee. Everyone that rebuilds a RB26 thinks they need to build it to handle 1000hp. Alot are built with too much overkill, hence huge rebuild costs.
They forget their factory built rb26 with cast pistons etc, has lasted 20 years now and did/can handle safely 300rwkw. Just need to be realistic with your goals.
I got an Autech, was thinking about getting a rs4 but the power goal I wanted was going to cost more in the end than buying an 260rs. Just think what you want in terms of power and cost. maybe worht getting a 260rs. Easier to build a rb26 up for more power than a 25.
I told him to talk to you brad! Basically everything i said to him, your the man in the know.
I think he wants to build it up over a period of time, hence going the 25 route, instead of laying down a heap of coin at once.
He has a RB30 block to.
Like Brad said though, the 30 bottom end wont have the AWD bolt pattern, so you will still be up for the added cost of the adaptor before you get to look inside the engine. Plus, dont forget the failings of the GT4 based AWD system, abysmal C34 brakes, axles, diff etc etc etc. Its not setup for the higher torque loading you are planning on putting it through.
Unless, of course a 2WD conversion is on the cards as well....
just sayin'
just sayin'
Im doing 5 speed and 2wd conversion on my s1 next week will let you no how i get on.
i ran mine is 2wd with about 345rwhp and snapped an axle from a 2nd gear roll on, it wasnt even from a launch, the axles are pretty bad unless i just got a dud one, the size differences to gtr/260rs is huge, same with the uni joints as well.
As i said with an engine build, the rb26 is the cheapest option i think from 25, 26 or 30 because u dont need an adaptor plate and can use stock rods for upto 500rwhp+. Throw a set of $1000 forgies in and some acl race series bearings, arp rod bolts and a decent oil pump and the motor will be fine for 500rwhp no problems, bolt on some low mounts for $2500 and it looks stock and goes like hell, plus u can reuse your oil and water lines and the exhuast all lines up. Clutch and fuel setup is obviously needed but thats needed with any combo.
rb30 will need rods and pistons and adaptor plate for that sort of power, and a rb25 will need valve springs, etc i assume at that power level, so the smart combo is definately rb26 head atleast, and then decide which bottom end u want. Dont forget a built 26 is gonna sell alot easier than a built 25 combo so remember that when you want to sell it or buy a gtr and put it in because the stagea is too heavy :(
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
