  • Replies 328
YAY Putty Road Cruise Im Definatly IN. so put me down for my 350z and put a + 1 just incase :) yay hopefully i wont encounter anymore possums before this one so my car is not off the road for another 2 months yay.
DIE POSSUMS
I think I've heard of this cop....hasn't he been there for years though? Cos we've done this cruise many times before without being hassled...
no no... hes still there. he has free reign.. he makes the police force sooo much money that he is referred to as "super" as in... detective, constable, sargeant, SUPER... he makes the police force sooo much money that:
he can fire his gun willy nilly without having to do a single ounce of paperwork
he can pull over a hoard of imports with a single hand and defect them at a rate of 2 cars every 15 seconds
he can create a new ADR with the power of his mind
he can change the speed limit signs by wriggiling his big toe
he is SUPER KEV!
he is SUPER KEV!
This is gold accept the only time he took more then 7.5 seconds to defects a car was when he met DRDOOF he ran out of paper :D
love you steve :)
ohhhhh you'se an asshole! :D
Hahahaha yea it had to be said. hahah i saw that video daniel took ages ago near ur dads place when u got done and you had ur hands on ur head like AWW come on this is bullshit lol
Meh, that wasn't a defect that time... that was the RTA de-registering my car for me without reason or notice... You'd do the same if some coppa took your custom plates off your car and then handed you a fine for $774 at the start of a long weekend! :D
Thanks RTA...
oh yeah, and then the cops 'lose' your plates for a week...
Thanks RTA...
Thats right hahahaha RTA Fail
They can has my plates as long as they swap for a non Yellow one :P and the last thing i need is a $800 fine.
It was actually pretty funny... after he took the plates off he starts going, you know, I could defect you for this and this and this and that and this... and I was just like, no you can't... IT'S NOT REGISTERED.
swiftly followed by a mega glare... ----> :D
swiftly followed by a mega glare... ----> :P
Hahahahaha that's the kinda smart ass comments that will come back to bite you didn't the same cop defect you hahahaha that might have been why
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
