I found a few things on the net about them, and was wondering if anyone found them to be interesting....
the first:
knock sensors on engines are set to detect knock at a certain frequency range, and shaving as little as 0.5 mm from the cylinder head can render the knock sensor completely ineffective as the change in combustion chamber also changed the frequency of the detonation, and they know this because when they stripped the motor and saw the detonation damage, they knew they had not recorded detonation via the knock sensors and I am sure this would not be widely known
The second:
A knock sensor can usually be tested by rapping a wrench on the manifold near the sensor (never hit the sensor itself!) and watching for the timing change while the engine is idling. If the timing fails to retard, the sensor may be defective -- or the problem may be within the electronic spark timing control circuitry of the computer itself. To determine the cause, you'll have to refer to the appropriate diagnostic chart in a service manual and follow the step-by-step test procedures to isolate the cause. Sometimes a knock sensor will react to sounds other than those produced by detonation. A noisy mechanical fuel pump, a bad water pump or alternator bearing, or a loose rod bearing can all produce vibrations that can trick a knock sensor into retarding timing.
Any thoughts??
https://www.sau.com.au/forums/topic/28674-knock-sensors/
Hi Guys, we had a car with an open wastegate pipe that used to set the knock sensors into a frenzy.
I don't know about the frequency of the knock being a problem, you would have to check the knock sensor specifications to determine its listening frequency range. But I have used RB20DET knock sensors on RB31DET's and they read the knock levels perfectly. That kinda discounts the "cylinder head shaving" theory.
Hope that adds to the thread.
https://www.sau.com.au/forums/topic/28674-knock-sensors/#findComment-592639
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
