World Of Warcraft Account - 2x80's // Horde Dk/priest! Awesome Gear!
Warning: Long arse post INCOMING!
- 80 Female BE DK (Xfer up!)
- 80 Male UD Priest (Xfer up!)
The gear my DK has:
Tanking is her MAINSPEC. All her tanking gear is EPIC gemmed.
Head: Conqueror's Darkruned Faceguard
Neck: Titanstone Pendant
Shoulders: Valorous Darkruned Pauldrons
Cloak: Platinum Mesh Cloak
Chest: Conqueror's Darkruned Chestguard
Wrists: Mimiron's Inferno Couplings
Hands: Conqueror's Darkruned Handguards
Waist: Indestructible Plate Girdle
Legs: Conqueror's Darkruned Legguards
Boots: Spiked Deathdealers
Ring1: Clutch of Fortification
Ring2: Mark of the Relentless
Trinket1: The Black Heart
Trinket2: Figurine - Monarch Crab
WEAPON: Worldcarver
That's her tanking gear. She has different trinkets, and a pretty decent DPS set. Also has around 550 resil in her PvP gear.
The gear my Priest has:
Head: Conqueror's Cowl of Sanctification
Neck: Symbol of Redemption
Shoulders: Mantle of the Preserver
Back: Cloak of Kea Feathers
Chest: Embrace of Madness
Wrists: Punctilious Bindings
Hands: Conqueror's Gloves of Sanctification
Waist: Belt of False Dignity
Legs: Legwraps of the Demonic Messenger
Feet: Savior's Slippers
Ring1: Renewal of Life
Ring2: Heartmender Circle
Trinket1: Tears of the Vanquished
Trinket2: Egg of Mortal Essence
WEAPON: Staff of Restraint
WAND: Fading Glow
I'll be checking this thread a lot, but I'd rather you e-mail or add me to MSN.
--For MUCH more info.. gold on account/bank mats (a lot of the former and latter) armory information.. and PRICE... MESSAGE ME!
CONTACT DETAILS:
MSN/E-mail: [email protected]
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
