Yea Paul it was on roo we didnt chase the tune at all. put some timing and boost into it and that was it.
wont be long till we race it i still have to put the auto in it and gas it{ i know gas is for fags IM GAY}
Paul what sort of power did your car make on a race tune? just curious not taking the piss at all :P
  • Replies 57
Paul what sort of power did your car make on a race tune? just curious not taking the piss at all :D
less power than you... :P ...with slightly less boost. Very safe tune though.
We thought it best to get the car set-up and running good consistant times with a sensible tune and reasonable boost levels. Ringing the engines neck while trying to get the set-up right is a bit silly as these engines have a short life at 1000hp+. Its now set-up right and quite consistant as the last 6 or 7 passes have been 9.7's or better with all the 60' times being in the high to mid 1.3's. Mark says there is lots left in it (about another 120hp at the treads with further boost and tuning) so ill be flying back up in a few weeks to run it again with a bit more power and set-up in the car. Small steps are the order of the day...trying big jumps can leave you frustrated and or a big expensive mess to fix.
any idea of how long till you take it out? remember the suspension guide i gave you...its a good starting platform and easier to fine tune from there.
good luck
Thanx mate. it wont be for about a month or two ive got other things going on{work shit}
so i still have to bolt the auto in and get shafts made but i will let you know
i know its easy enough to make the power we just have to get it down the track
Edited by superjet760
Ok dyno dynamics could read high but knock 200kw off the figure and im still making 300kw more than most :P
i lol'd.....to save an arguement...get Vic to do it in 'Shootout' mode...its the industry standard and cross-references directly to Mainline figures.
dyno's are for tuning anyway...racing is the true measure of performance.
id like to see it run so stay in touch before you take it out.
Haha its been a while since the last "flame someones dyno figures" session on here.
Nice work Superjet, sounds like a very impressive setup - be good to hear how it goes on the strip. I know RIPS has run around 150mph in a full weight R34 GTR without NOS and slightly less boost on an RB26/30 with the same or less amount of "turbo" so while I can't make heads nor tails of how different Oz dynos read, I know that if your head is good and the tune is nice - a 26/30 with a bunch of turbo, good fuel and 30psi can make for a very hearty amount of power.
Edited by Lithium
Well done mate, glad it worked out well for ya.
Was good talking to Con last week, we discussed a few things and I told him to go for it as we'd been alot further than you wanted to go with the same bottom end setup.
Best of luck mate, get the gas on there and let me know how me old auto goes too :D
Rob
Edited by R.I.P.S NZ
Rob is this the Turbo400 4WD you been working on?
Nah, this is a different set up alltogether.
The TH400 is all but done, I'm just waiting for the car to get here from overseas thats going to be our test mule.
Rob
