New look forums
By Dose Pipe Sutututu 路 Posted
I wouldn't run it post throttle. You might run into scenarios where on partial throttle, pre throttle there is more pressure than post. Anywhere before the throttle and after the turbo. -
Yeah I have the same mods but no heat exchange too. Had my local exhaust guy fix the the awful sound it makes when you put on downpipes or High Flow Cats. I'm looking at a tune too but I'm thinking getting a LSD first. I got some Michelin pilot Sport 4s but that was a long time ago and need a new set soon. Tyres, Tune, Heat exchange and LSD. Money money money 馃挵 馃挵 馃挵
By rb25ceffy0 路 Posted
Have an rb25det series 2 that runs well on stock ECU but when plug 20det nistune ECU in that has been mapped for the setup , it misfires and only runs on 5 cylinders . Have narrowed it down to #1 coil plug not getting any signal with the 20det ECU but runs on all 6 with the 25det ECU. Is it possible the coil driver inside the ECU is faulty ? -
I've been sent a new main board to replace the suspected broken one. I haven't taken the screen out to look but I'm I'm assuming it's all plug and play.
