  • Replies 85
Posted Images
How much for the 4 brake rotors only?
Thanks
Hi only have the rears remaining....
Hi bud im after some parts for my skyline if you got them, I need drivers side Blinker on the guard, indicator switch on the steering column, (series 2) and also I need the surround on the window switch on the drivers side door, Im in sydney too how much for these items, Also if you got a good clean radiator shroud I might take that too cheers, 0422992242
pmed you mate.
Hi SAU
Decided to wreck my R33 s2 and not repair after a side on.
This car was in mint condition with 93,000klms.
So here is the list: By all means PM me if anthing your after is not listed.
R33 gtst s2 Complete 93,000 klms engine $2000
R33 gtst s2 gearbox $1600
ECU to engine Harness $220
ECU $150
Radiator $150
K SPORT height and Damper adjustable suspension $1000 (less than 5klms near new)
Air filter with adapter $80
cat back exhaust $350
front bar complete with foggies $450
front guard lhs or rhs $100
bonet r33 s1 in black $250
RHS R33 s2 headlight $280
front grill $150
front reo bar $220
rear bar $120
m spec side skirts $150 pair
m spec rear pods $120 pair
Door $150 each
Mirrors $80 each
taillights $90 each
Skyline rear garnish $60
boot lid $100
s2 rear spoiler $100
brake light $60
GT badges $55 delivered pair
Front m spec lower lip $150 couple cracks in plastic
Power window motor with regulator $150
Power window Drivers switch $95
front seats $300 pair complete with rails
rear seat $150
Door trims $90
s2 Steering wheel with airbag $270
rear parcel shelf $90
r33 s2 gear surround $90 very good nic
Drivers PW surround $90
climate control unit $90
Complete 5 stud setup $1000 (Will separate bits; PM me).
Lower control arms $100 each
Front hubs $120 each
Hand brake cables $150 pair
Front rotors $100 (near new)
Rear rotors $90
Front Calipers $350 pair
Rear Calipers $250 pair
LOCATED SYDNEY: HAPPY WITH PICK UP OR DELIVERY AT BUYERS EXPENSE.
ANY BITS NOT LISTED PLEASE PM ME. :D
Im located in sydney
interested in dash surround, gear selector surround and plastic mould under steering wheel
sms Manny 0406747726
Hey Hey,
Just wanted to know if the following parts are still available and if you could please send some pics or wherabouts you are located so i can come have a look.
1) Front m spec lower lip $150 couple cracks in plastic
2) front bar complete with foggies $4503) RHS R33 s2 headlight $280
4) front reo bar $220
Thanks :D
Hi SAU
ECU $150
Radiator $150
front grill $150
front reo bar $220
rear bar $120
Door $150 each
Mirrors $80 each
taillights $90 each
boot lid $100
brake light $60
rear seat $150
Door trims $90
Rear rotors $90
ANY BITS NOT LISTED PLEASE PM ME. :blink:
  • 1 month later...
  • 3 weeks later...
hey mate i cannot pm u as have not got 10 post how stupid but will take the grill condenser and headlight for that s1 33 delivered to bundaberg so if you wanna send ya phone number ill give you a call and get ya bank details of ya thanks man
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
