Gday,
Lots of bits that are taking up valuable space in the shed!
GTR AFM's, taken off my GTR as I went with a ecu using MAP sensors... ready to plug in if your current ones are doing funny things!
- $200 (pair)
Tuned ECU, specifically a tuned standard R33 GTR computer, made 187kW (11psi) at all four wheels with no dramas (dyno sheets to prove if you like), good upgrade over the standard ECU! (Appears as if it is it tuned for up to 17psi by D. TECH SQ).
- $200
Swaybars (standard) off an R33 GTR, front and rear!
- $150 (pair)
Air-con "kit" taken off my GTR, includes everything in the engine bay; compressor/condensor/fan etc. If you have an N1 GTR, summer is coming up so get in quick!
- $200
Active-LSD off Vspec GTR that has done 85000kms, works great but not needed, only locks up when you need it too!
- $500 (including lines to ATESSA pump)
Bridgestone Potenza RE050 in 245/45/17, set of four, two are in great condition with plenty of meat left however the other two are not so good.
- $400 (for all four, rims not included)
Can organise pick up, or delivery (if you are local around Adelaide) can also arrange postage anywhere at buyers expense. Feel free to PM or call/SMS 0432 562 025.
All price are negotiable!
Mike
Edited by bigmikespec
https://www.sau.com.au/forums/topic/287721-r32r33r34-gtr-parts/
Is the A/C Kit for auto air? Mechanic told me to ask lol.
Any idea if it would fit onto series 1 r33?
Also, any chance I could grab some part numbers?
Thanks in advance
Auto air? I am not sure mate, I have an "auto" button on my climate control unit if that is what he means.
It should fit but I can not say 100%, I will have a look for part numbers tonight and get back to you.
Mike
New prices in bold for items below:
- $200 (pair)
- $200 --- now $150
- $150 (pair) --- now $120
- $200
- $500 (including lines to ATESSA pump) --- now $450
- $400 (for all four, rims not included) --- now $350
Need this stuff gone!!!!
Mike
Rear swaybar sold... thanks "bin".
All other parts still available, with front swaybar: $60
PLUS... a standard GTR fuel pump, done 86000kms: $70
Mike
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
