folks,
just a quick thumbs up for the aforementioned tyre. i've had them on the vehicle for about 5,000km's with 2 trackdays and they are holding up extremely well, i predict them getting to 15,000km's without any drama's. I have 17inch all round, 255/40 on the rear, 235/45 on the front. Suspension setup helps alot though, i have Whiteline swaybars, camber & castor kits aswell as a rear diff brace.
In the Wet:
fantastic - you can easily light up the rear's but i put that down to a function of high powered rear wheel drive rather than lack of grip. Put it into a corner and it turns without understeer, maybe a touch of oversteer. With traction control on, its like driving a AWD - it has that much grip. In heavy rain i have never experienced aqua planing, water just washes off them...
In the dry:
sublime - grip when you need it without squeel or road noise! i am absolutely dumbfounded by the amount of road noise these tyres produce - practically none! for its soft compound nature, the road noise of these tyres are amazing! tyre wear is also impressing me especially after 2 trackdays and 5,000km's.
On the track:
utopia - im sure an Rspec tyre will have alot more grip but for the money i paid you just can't go wrong. just after the suspension was installed i had the tyres put on aswell. on the first trip down the car was terrible, i was understeering all over the place. dropped the tyre pressures on the front and it pulled it back in a little but it still had excessive understeer. on my return trip i tweaked the rear sway bar to its hardest settings and played with tyre pressures till i had the car almost the way i want it. it still has some understeer but the its more nuetral than anything. thumbs up.
they come highly recommended and i will definately be getting them again pending its tyre wear...as i said i've only ran them for 5,000km's i'll have to report back how much i actually get out of them - perhaps in a year or so then i guess :cheers:
price?
~$1300 fitted & balanced for all 4.
Yep - concur fully!
I had Trampios on my car when I bought it - everything you say.
I didn't replace them because they wore too quickly on the inside and outside, but this turned out to be worn bushes on the upper control arms. I went for Firestones instead and while I don't have any complaints about them either, I seem to remember that the Toyo's gave noticably better grip and especially feedback.
so how much each? about $250 ?
thats hella cheap for 2x 255s and 2x 235s fitted!
need new tyres in the next week, wheres somewhere to get them in brisbane?
Hornibrook Motorsport sells them. He was handing out flyers last time out at Queensland Raceway. His business is pretty new so he would probably do you a good deal. I am going to give him a call when I next need tyres, he speciality is R-spec tyres so he seems to know his stuff. He is a mad keen motorkana man too so he speaks from experience. Unit 1, 5 Basalt St Geebung. 07 38651072. Let us know how you get along, like I said haven't bought anything off him yet, haven't needed to, but he seemed good.
buzz, great to see someone else using them, you mentioned that you bought the car with them on, do you have a rough estimate as to how many km's you put on them before they had to be replaced and how much tread, % wise, was on them when you bought the car?
rob, no probs. hope they impress you as much as they've impressed me!
knore, unsure of availability in brisbane, i would say goto your local and see if they can order them in at worst case? price was $300 for fronts, $350 for rears - they'll usually help you out on installation costs if you buy the whole set ...
  • 7 months later...
Any ideas why Toyo's australiab web site says they are only avaliable in a 215/45 17" or a 205/50 16" ? Are you sure you got a 255 in a R1R and not the RA1? I rang a toyo dealer and they say only RA1's are in 255/40 17"
Comments?
Ok I rang stuckey tyres and they say they have a 255/40 17" in R1R's. The Toyo web site must be old. The price was $519 each! where did you get yours from? Cause if I could get $350 for 255/40 17" I would buy them now.
Yeah tell me about it... I've been trying to get something going for about two months thou.
Firstly the budget simply doesn't stretch to $520 a tyre. Everywhere I rang for the Toyo's said 500 - 520. The Bridgestone RE55 are not going to be in for at least another fortnight. (Have been calling the guy for months to keep checkin') The Falken's are in shortage due to a fire in Japan or some shit like that. No one's got any of them!!
You got any other suggestions for me?
Here is my research so far. Based on a 255/40 17", per tyre.
Falken Azenis ST115 - $320 - No stock
Falken Azenis RT215 - $340 - No stock
Toyo Trampios R1R - $519 - Avaliable
Toyo Proxies RA1 - $460 - Avaliable
Yokohama A048 - $520 - Avaliable
Yokohama A032 - $548 - Avaliable
Bridgestone RE55 - $400 - In a container at customs
Dunlop DJ01 - $521 - Avaliable
Scotsman, there is a place here in Adelaide that does RE55S 235/45/17 for around 350 each fitted, Not sure about 255/40/17. If I go to R rubber on the rear again, I will be going 235 in the RE55S, as they seem to be damn near the same width as the 255/40/17. They are wider than the RE540 in the same size anyways.
if you like I can get his number and he can send some over. They told me they send them over pretty regularly.
Yep, that's Kym at Magill.
The inside of the tyres arent holding up so well with only 2 deg camber - but the rest is good - excellent grip and great handling. Heaps of tread on the outside, so it looks ok:p
Havent measured them exactly - but they sit wide on the 8" rim up front, wider than the rim slightly - lucky it has such a stiff sidewall. I might take to em with a tape measure tonight:)
One day late but here nonetheless:
Trampios R1R 255/40 x 17 = $350 a corner.
235's and 245's are low in stock.
limited supplies till further notice, so place your orders.
email me.
i can also get Dunlop R Specs, just confirming on price and tread pattern.
shipping to melbourne can be organised.
Franks,
Thanks for you efforts. But since I need them on the car today or tomorrow I will have to go with something local.
I will keep these in mind for next time thou, as I would have gone for this if I had more time.
Is this a special price for you, or can I contact this dealer myself when the time comes for more rubber? Who is this through? "Kym at Magill" I assume?
Thanks again.
So these grip really well in dry?
Im after a soft compound tyre that really GRIPS in the dry
I was leaning towards Falken RT215s, i know u havent used these, but how do u think they'd compare?
They are both about same price, from looking at the grip, the toyos are semi-slicks yes?
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
