Heyy guys wast just curious if anyone would be up for a photo shoot just got my car fixed after it was bricked and wanted to take it out for some pics!! Dont have a very good camera so i thought id ask if anyone could help me out or if anyone wanted to come along that would be awesome the more the better :)
Even if anyone has suggestions for a location let me kno!!!
Thanxxx guys :ph34r:
https://www.sau.com.au/forums/topic/287835-photos-anyone/
  • Replies 49
Yeah I'd be keen. I'll bring down the GTR.
Just name a date/time/location.
Sweet as well thats 2 of us :ph34r: then still gotta try n find someone who can take the pics!!! Time n date ill try n organise most likely on a sat or sunday either day or night whenever everyones free!!!!
https://www.sau.com.au/forums/topic/287835-photos-anyone/#findComment-4824087
Sweet guys well ill try n organise a definate date ill pm you and see when everyones free coz d weather is startin to look a lot better and would be great for some piks!!! :P
Anyone got a location in mind or have allready been to a good place??
https://www.sau.com.au/forums/topic/287835-photos-anyone/#findComment-4824791
5th October, cruise to mallala for the gsr/evo rally time attack? ill finally have my SLR on that day, so it will be good to muck around with settings.
Goin down to mallala is also an option and wuldnt mind helpin u get sum practice on that camera of yours :P
https://www.sau.com.au/forums/topic/287835-photos-anyone/#findComment-4824797
Yere count me in as well.
No problems this is turnin out bettter than i expected :P nice to c sum1 reppin the stags :P
Will post details of the shoot as soon as a date, time and location are organised. Will also pm all those interested in coming sooner to the date!!!!
https://www.sau.com.au/forums/topic/287835-photos-anyone/#findComment-4825410
Good idea, then you'll be able to take pics of me carving up the track :)
https://www.sau.com.au/forums/topic/287835-photos-anyone/#findComment-4825735
I have a SLR and I got NFI how to use the settings,
I'll bring my camera too Damo and if you know anything you can teach me :P.
Only thing I know how to use is the long exposure shots but for that I need a TriPod -___-
https://www.sau.com.au/forums/topic/287835-photos-anyone/#findComment-4826080
wayne, sau has a brilliant photography section with plenty of tips and links floating through it.
but the best way to learn is to spend a lot of time f**king about with it, dont try to be macho man and use full manual settings (im yet to meet anyone that uses full manual for anything... cept me with the 35mm) just focus on either aperture or exposure settings, dont be afraid to use manual focus, and dont be afraid of experimenting.
https://www.sau.com.au/forums/topic/287835-photos-anyone/#findComment-4826088
I'll bring my camera too Damo and if you know anything you can teach me :P .
jesus man... how can u own an slr and not know how to use it? generally its the other way around
if i see u on a meet with ur camera, i can def give u a couple lessons but generally there are 3 things to worry about
a) ISO rating
b) depth of field
c) focus
get them each right and u wont have an issue. Depth of field is a floating art since it varies depending upon ur aperture and the type of lens u use but thats a dark science for the pros to play with - if u have a fixed lens slr its very easy to get used to the details
-D
https://www.sau.com.au/forums/topic/287835-photos-anyone/#findComment-4826130
Dave do you remember doing the Fulham car park and Windy Point thing where we had a bit of a play with my Canon SLR?
I've got a Nikon these days so once the weather gets somewhat better, I wouldn't mind finding some free time (if there's any such thing) and have another play with exposure times and rates.....maybe your car and my bike or something, around the Christmas period or before. :P
https://www.sau.com.au/forums/topic/287835-photos-anyone/#findComment-4826148
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
