General Meeting West Pre Meet N Greet.
With the General Meeting being this Tuesday night Antony (nismo GTST) and i thought
we would put together a couple of meet n greet style cruises in to the GM.
I will run one from over here and Antony one in the West. For a few of reasons.
1..It saves people driving all the way alone.
2..If you dont know where to go . We can get you there.
3..If you wanted to go to a meeting but you didnt know anyone..Now ya will.
4..It a Tuesday night and what else is there to do.
5..Not to forget it sounded like a great idea..
So here is your chance come and join us Tuesday night for a run into the city.
PLEASE NOTE THIS IS NOT A OFFICIAL SAUvic EVENT. :) ..
So everyone welcome....Members /Non Members
EAST ... No interest shown..
WEST..
Meetpoint..In bound Ring rd Mc Donalds
Time.........6.15
Depart.......6.40
So i hope to see alot of new faces and even some old..
Here is a link to the GM thread.....GENERAL MEETING..
Cheers
Wayne..
MODS..Please leave for 2 days... :ph34r:
Nice work Wayne.
This is a good chance for new people to meet and greet in a friendly environment before the general meeting (not that general meetings aren't friendly). Will no doubt see you guys at the east meet.
im already in the city,... :P not like im doing much tmrw night anyway :P
oh yeah the GM thread i get it now.. ohhhhh i'm not a member does that mean i cant come?
Edited by atomaly
You dont need to be a Member to come.
Hope to see you there..
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
