Since ACT rego seem to want to stuff me around, anyone on here able to confirm how much bigger profile tyres I can run vs standard? Ie is my cars came with 205/35 front tyres can I run 235/45 or whatever?
Also what about diameter of tyres?
https://www.sau.com.au/forums/topic/287887-profile-tyres-and-act-rego/
CeJay, I cannot confirm with the R32, but my rim/tyre combo are engineered and passed through dickson. 235/40 front and 265/35 rear. (Std for R33 I was pretty sure are 205/55 or something like that)
The diameter of the tyre doesn't matter as long as you don't modify the rolling diameter (much). Which is tested with the GPS by the engineer against your speedo.
well ended up giving canberra connect a call and they ended up saying the following.:
Rolling diameter can't go up more than 15mm.
Track can't go up more than 25 mm etc.
Just need to check if my "235/45" profile tyres will be withing 15mm of the standard r32 profiles.
i assume you meant 205/55??
diameter of the tyre depends on the size of the wheel (ie 16 or 17 inch + the side wall of the tyre) the standard r32 wheel is a 16inch.. so are you running your 235/45 on a 16 or a 17 inch wheel?
235/45R16 is 7mm smaller (rolling diameter) than a 205/55R16
however a 235/45R17 is 18.4mm bigger (rolling diameter) than a 205/55R16
This is all assuming that the tyres arent stretched too much over the rims
Track is all to do with the offset of the wheel as compared to stock so i got NFI on that front.. i think stock r32 (non GTR) offset is around +40
why dont you just borrow someones stock wheels to get your car over the pits?
Edited by nerm
I'm running it on 17 inch rims at this stage I'll probably just be swapping my 235/45 profile tyres onto my 7.5 inch wide 17' ROH rims. Will confirm the tyre placard tonight as i think they were slightly different front to rear. Otherwise I'll get other rims.
japs tend to have different sizes front and rear. my car comes stock with 205/55R16 Front and 225/50R16 on the rear.
im currently running 235/45R18 front and 265/30R18 rear. Strangly enough 265/30R18 is only 17mm bigger than 225/50R16 on paper but it actually comes at about 14mm because the tyre is streched
Chris this is all about the overall diamater of the rim and tyre combination and is best explained by the attached Toyo tyre chart.
The standard Skyline tyre size is 205/55R16 and has a diamater of 634mm and this means that any tyres that are between 619mm and 649mm are legal on your car.
Some common tyre sizes that guys run are:
235/45ZR17 644
255/40ZR17 636
235/40ZR18 644
265/35ZR18 644
The other interesting point is to try and find common sizes that are sold in larger numbers as the unit cost will be lower (eg on my R33GTS-T I run 245/40ZR18 on the front and 265/35ZR18 on the rear and the 265 are about $40 cheaper per tyre).
Toyo_Proxes_4.pdf
the 634mm will change depending on the width of the rim and the stretch of the tyre. what is the width of the rim that that measurement was taken from?
well looks like my tyres might just scrape in
r32 runs 205/55 R16s on the front
225/50 R16's on the back
or 631.90 and 631.40
235/45 R17 rims are 643.30 mm rolling diameter
http://www.sr20tuning.com/tyresize.html
and yeah I've finally got my tyre placard, thanks for the help though
  • 3 weeks later...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
