Hey guys,
Just wondering what everyone else has done! I've nearly finished rebuilding my rb26 and don't want to put the ceramic turbo's back on as I've heard many disaster stories. Everyone says that getting them rebuilt with steel wheels isn't worth it and one shop said i'd be better of buying new garrets that are slightly different and pop riveting on the old plates. Are there any new garrets made that replace the old stock ones? The car has to go through regency! Is this a viable option? Or does everyone just get there standards rebuilt? If so where in Adelaide as the place I asked didn't want know about it.
Cheers
MAtt
https://www.sau.com.au/forums/topic/287942-standard-turbos/
Go throught Regency with stock turbos, then put on a set of Garrett GT2860-5's (bolt straight up). Im making 324rwkw on 18psi but with a built motor you'll be able to wind up the boost and make 350-400kw's :) Unless you've only done a standard rebuild?
https://www.sau.com.au/forums/topic/287942-standard-turbos/#findComment-4825602
ring up Bill Keen as the RB26 factory turbo is a garret job he can supply you with paper work that states they cannot be purchased brand new anymore and will supply regency happy paper work that says the replacement is 2860's
ring Bill he can explain it better
Adelaide Turbo Services
Bill Keen
953 Marion Rd
Mitchell Park SA 5043
(08) 8377 2511‎
https://www.sau.com.au/forums/topic/287942-standard-turbos/#findComment-4825637
That's what I will probably end up doing but I'm just paranoid about killing the new engine! I guess if i just drive in and drive out. Have you been hassled about your turbos!
I've only been pulled over twice since installing the RB26 and both times the cops didn't even ask to see the engine, and one of those times was at a mobile defect station at the bay. I've been pretty lucky so far. Looking in my engine bay you wouldn't even know that my turbo's aren't standard. Just keep the standard heat shields on and no one will ever know unless you go to regency.
https://www.sau.com.au/forums/topic/287942-standard-turbos/#findComment-4825693
My mate has been through regency with the Garret version of the 2530's on his gtr and passed. My other mate went through last week with a gtrs on his s15, no questions asked. Keep stock heat shields on and the engine bay stock looking.
https://www.sau.com.au/forums/topic/287942-standard-turbos/#findComment-4825708
Bill Keen
953 Marion Rd
(08) 8377 2511‎
Madaz,
Is that all variants of the 2860's
https://www.sau.com.au/forums/topic/287942-standard-turbos/#findComment-4825836
not claims been told if straight from the horses mouth martin donon to my knowledge claims a similar thing
f**k
i wish i knew about this before i shelled for a pair of blown turbos and paid a $200 deposit on a rebuild
fkn spewing
-D
https://www.sau.com.au/forums/topic/287942-standard-turbos/#findComment-4826057
yeah I suppose at the end of the day, it's all about emissions.......if you fail that due to a turbo change then you're gonna be stuffed no matter what you're running
the turbo change itself isnt going to cause emissions
its the ability of the auxilliary gear
with a top end turbo, if they got the right resolution for their afms, o2 sensors, the ecu control over their injectors and sparks, then i dont see a reason why the emissions cant be equalled or bettered
-D
https://www.sau.com.au/forums/topic/287942-standard-turbos/#findComment-4826162
yeah I know how things work Ben but generally peeps that run 2860's also usually add a set of 700's (or similar) followed by an ECU upgrade to pull the fuel back out and all of a sudden you've gotta a ride that won't get thru Regency......but I take on board what you're saying.
https://www.sau.com.au/forums/topic/287942-standard-turbos/#findComment-4826195
thing is tho, regardless of the fuel air and boost ur pushing in the mofo, if ur afms and fpr are working fine, u should be able to get a 100% epa approved tune all the time. as long as ur ecu and sensors can deal with the settings, or they have more samples per second to correlate the lambda against, u shouldnt have an issue. ur right tho pete, most people who do the cheap mods dont care about such things but im going to make my car a case in point if necessary. a 100% street gtr with legal mods and none to shabby performance.
its laik that shampoo add.
it wont happen overnight, but it will happen
-D
https://www.sau.com.au/forums/topic/287942-standard-turbos/#findComment-4826211
Spoken to Martin myself about this issue and he seems to think it should be no issue at all :banana:
I like the should part :D
Does anyone know someone who has actually been through with such a letter?
https://www.sau.com.au/forums/topic/287942-standard-turbos/#findComment-4827866
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
