  • Replies 140
twink as in skwiz twink or...?
correct
of course you understand the nickname twink, yes?
no im just jumping on the bandwagon
feel free to elaborate via pm if you will
GODDAMNSHITFARK! i have nothing to do with this thread yet i am mentioned!
There is no bandwagon mitch. Its more of a single seater failwagon that Dave rides continuously.
*awaits a 'your mamma' joke from daves book of fun*
*obliges diligently*
only single seater failwagon i ride continuously is your mum.
:D
side note jake, got your shit sorted for tonight?
probably gonna be quiet in town, so your name on the door list probably isnt required, but its there.
Edited by scandyflick
[sCNDBTCH]?
Oh and turns out she cant make it tonight, which sucks balls.
So the only time that was ok is tomorrow for lunch down the bay. Just so happens to be Grand Final day, and im going out tonight. Ergh...
lol. mass fail. all that effort for nix.
which sucks balls.
i do believe youre mistaken, there will be no sucking of balls...
If he picks something else up tonight it is possible that balls will be sucked
I like that thinking.
How much are CC plates going for these days? they suit most cars..
In SA anything but the metal plates issued by Transport SA are illegal.
Prestige plates are plastic. Consist of white numbers only printed on a black background.
are cc plates paid per year? or a one off?
its a one off payment of $150
Yeah something like that. $70 for the plates and $70 to purchase the rights
as above.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
