Hi Guys & Gals,
When I was cruising Yahoo auctions via Import Monster last night I stumbled across 2 x very nice original R/S badges on page 7 of my DR30 search.
They have a starting figure equivalent to AU$74.00 and if you think like me, they would be a good investment for your ride for when yours are old & crazed and or cracked.
Cheers, D
https://www.sau.com.au/forums/topic/288179-dr30-rs-guard-badges/
I bought a pair of new RS guard badges recently, plus the front bonnet "S" and rear bootlid "X" emblems direct from Jenesis' Yahoo Auctions Japan shop. Definitely worth getting if you're into the whole restoration buzz like I am :O
They can be ordered new through Nissan NZ/Aus, but it's far cheaper and faster to source them direct from Japan. I used the Hayatonka middleman service to purchase mine, the guy who runs it has very reasonable charges compared to most. Plus as an added bonus for purchasing from Jenesis they included a couple of bonus items - a large "NISSAN PDC" sticker and small "Strongest Skyline Ever" decal.
another Yahoo shop that sells the badges is Carshop Omote - see here for their current listings, they have other genuine parts as well.
dus anyone here know were i could find a dr30 rs complete with or without engine and gearbox
minor bodywork okay minor rust okay.
in perth
cheers
I just listed one for sale today on behalf of an older lady, an '81 4-door DR30 RS non-turbo. Has been her daily driver for years now, but she's looking to get something more modern.
A shame you're in Australia and not New Zealand, otherwise it could probably have suited your needs. The current owner is only looking for around $3-4k.
with that said, I do have contacts in vehicle shipping...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
