hey guys i have a rb26 with power fc and rb25afm
i got the car tuned about 4 months ago it was purring like a kitten running perfect then i pulled the engine out and painted the engine bay, i also painted the engine covers so i had to take the cas off and i didnt mark it probably but ive got it as close as possible and now it starts fine idles for about 10 seconds and shuts off, but when its hot 72 degrees it will idle for 6 days if i wanted to.
ive tried everything ive cleaned the airflow meters
checked all connections
before i took it out i had the 02 sensors still in there but i spoke to the tuner and he said they were switched off when he tuned it so i didnt put them back in could that have anything to do with idle?
cheers
which one is the air regulator is that at the back of the engine under throttle bodys or under the plenum? i havnt touched anything since it was tuned? the only thing ive changed is the cas and when i removed it i didnt mark it very well, will the cas cause it to stall on idle?
its under the plenum...it has a rubber hose attached either side of it.
i removed mine from my drag car and it does exactly as you have described yours is doing now.
yer mate just checked ive got the two pluged in under the plenum ones going to where that screw is for your idle and the other to the air regulator like under the throttle bodies the blue plug is going to the air reg and the blown is going to the other?
the procedure for testing the air reg is in the workshop manual...do you have a copy?
do a search online and you should be able to download it somewhere.
tried a another air regulator still no go? how much are they supposed to open up does anyone know? should you be able to see the hole way through the 2 holes or is it only about 1mm its open? because this one only opens about 1.5mm really small hole?
maybe i bought a faulty one, i dont want to go out and spend 220 on a brand new one when it mite not be the problem?
any ideas
In the powerfc, go to ETC > Sensor check, do that first while the problem is evident (when cold).
Look for any values highlighted with a black box around them. If any are highlighted, the parameters are incorrect, which means faulty setting, sensor or wiring. Your exhaust temp light should be on if there is a fault, although considering the engine is transplanted then it may not be connected.
If there is nothing, it could be your air reg. It could not.
ok guys i had a look and when the car switches to accessories the ignition, eccs, and idle lights up but when i switch the car on the fuel pump light comes on as well
what does this mean? ecu? fuel pump? anyway to test these
no, no those are normal.
youre looking for values that are highlighted, not the circular dot type things. The idle should constantly be on when youre not touching the pedal, then off when you open the throttle, but it wont cause your problem.
if no values are highlighted then sensors are ok. so look for faulty actuators ie air control valve or other.
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
