The resonator helps reduce NVH from the motor making the car seem more luxurious/smooth. The z tube from US cars has no resonator though. Without analysing it too much, having any form of resonator should create a bit of turbulence and decrease of air speed which is not what you want for the car...unless of course you want it to be more quiet etc.
Ask Alan/Scathing, pretty sure he's taken his tube off before and noticed a small resonator on it.
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4830751
Honestly, I would get one from the US. The US Z tube is better and being from the US works out a lot cheaper.
Shipping usually takes four days. I got mine from Riverside Infiniti, however there are other vendors out there, that are as good as if not better.
G35driver.com and Google are your friend.
As for install, seriously, 10mins with your eyes closed.
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4830841
You don't even need to take it off to see it.
Here's the AuDM intake pipe on my car:
See that branch off the intake tube, just right of the strut brace? The one that seems to be a shortcut to the intake plenum in the photo, but in reality goes nowhere? That's the resonator.
Here's a USDM engine bay:
No "appendix" on the intake tract.
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4831915
Dose a Z tube add any "real" power to the car? as in has anyone bothered to do a dyno test or anything... I just cant see there being much of a gain particually on a NA engine
Agreed. I dont know what the facination is with the "z tube". May as well just grab a proper aftermarket item, or leave the stock one there...
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4834256
There is no real power gains from the Z tube as far as I'm aware. Its a cheap intake mod which reduces restriction compared to the factory V35 intake pipes and as a bonus it gives a more aggresive engine note above 3-4K RPM. If you get it cheap why not...if ur gonna pay $200 for it I say go but an aftermarket shiny one with pod filter.
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4834263
I did all before and after test on my mods. Plenum spacer, Z tube and JWT pop filter. about 7rwkw on the spacer and another 8rwkw on the Z tube and filter
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4834478
SO what ur saying is that the spacer was good for 7kw on its own
and then with a filter + the x tube it was good for another 8kw? was this done on the same dyno on the same day @ around the same time as 8rkw from just a ztube and filter sounds like a big gain for what they are
so in total you netted an aditional 15rwkw by having the spacer the ztube and the filter?
https://www.sau.com.au/forums/topic/288251-z-tube/#findComment-4834502
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
