hey guys how are u
benm: unless u have something huge mounted between youre plenum and strut tower, ull have room
B-MAN: piping doesnt cost very much, so buying without will not make much of a change at all....
BANZAI: yes, u can buy one! when suits you?
  • Replies 47
Player_Hater: yes we do! but u need to come round to our factory to have the bracket made individually....when suits you?
BMAN: they have a internal downpipe that directs the fumes into stainles steel mesh where it condenses..theyre not just hollow cans like those "bargain" 90 dollar autobarn ones.....
BMAN: i talked this over with parents and money order is our preferred way to go...so yeah if you wanna hook one up at youre local post office i can have it posted out to you the day i recieve the money order :(
is that ok?
I think that most people who have done a lot of internet buying and selling would be fairly disenchanted with cod. It is comparatively expensive to use, doesnt give any real guarantees to the buyer, and if it's not picked up the seller has to wear the cost both ways .
yeah guys a money order sent thru registered mail is the best way to go. its easy, and if u send it via registered, if it gets lost in transit u can cancel it, get a refund, and we can start again. COD just introduces a lot of hassles.
i am sending 2 kits off to queensland today, after recieving a money order just yesterday. its really a very short turnaround time, and it saves me having ppl say "ok i got it, but i cant get the money off for a few days/i get paid next week/i got a speeding fine etc.
its just easier as you get the kit as soon as u show u have the $$......less hassles for everyone....
yeah, well i guess if its all the same, money order is cool too?
my dads company is making these, im not getting them for free...hes got a lot on his plate and is doing this for me as a favour and to help you guys out. he just would like to see a money order before he ships a faitly intricate and time consuming part to the other side of australia...and thats fair enough id say.
im sending 3 kits to brisbane this afternoon, no probs.
Just making sure...
These kits...
Have EVERYTHING needed to mount them yourself in a short time?
No fabrication needs to be done?
Just mount it and connect the hoses, correct?
Have u installed these on an R33 yet?
Anyone?
Not doubting, just want to be certain
Just for interest
Mon 12/1/04........GT-spec15 pm'd me his name & addy for money order
Tues 13/1/04.......Sent off money order, ord mail
Thurs 15/1/04......pm received acknowledging receipt of m.o. and promising to send oil can
same afternoon.
Assuming all is well, should arrive Mon or Tues........Will repost when it arrives
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
