Official SAU Tokyo Auto Salon Contingent...
  • Replies 78
rezz, thats correct! 6 guys! incl. me....what are the chances of moving 20 guys around the place! haha like to street meets, drift action etc etc!!! hahah.
Sounds pretty difficult! Altough never undestimate the holding capacity of a Toyota Estima... :rolleyes:
Sorry, I meant Toyota Estima "rent-a-car"...!:rofl:
hehe, i am going to talk to the boys about renting a car in japan. i think that will be the way to go if we were to go and travel into the mountains etc....
it might be cheaper than catching 2 cabs everywhere aswell (where we can't catch trains) ... but were right next to tokyo central station, so it shouldn't be too difficult!
TAS04 is on the weekend of 10,11 and 12th? of January.
20 guys in an Estima - should be possible! :rofl:
Rezz, I should be able to go (wife and son also). Just wanna confirm with everyone on the thread - what day will the SAU be invading the TAS??:D:D
Friday is open to the public, but I believe it's from mid afternoon only.
Oh, for anyone wanting more info on the event look here
Hahaha we are 2 stops away staying in Chiba. 15 minutes via train
That Makuhari website and the autosalon page have loads of helpful info no how to get there via train/bus/car
Should make things easy
yeah, but IMHO, you're too far away from the centre of the city!
TAS is only 1 day for us! we have 10 days in Japan.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
