hey guys this is a funny one im a apprentice at magic nissan and they have a r32 gtst auto skyline that is stalling and cutting out but it is intermittent and we cant plug consult in it and they wont listen to me and i would like someone to help me help myself at work so i can go ha i no :D cheers any info wood be great
Do R32s even have a port for consult support? I thought they relied on the flashes to throw codes ??
What is the arguement between you, and the people giving you your qualification?
Since none of us work there, we cant just walk in a stick up for you :D
How intermittent ? more details man, it could be a trillion things...well...lots of things, at least
intermittent weirdly like randomly aha
also it has trhe old consult port which we do have and also if u plug consult into imports it blows the consult up is why were not allowed imported r35s in aus
Yes R32's do have a consult port. I have datasan and a consult cable and it works fine.
Does this car have an atmo venting bov? they are the usual culprits for stalling when coming to a stop. The other things that can do it are vaccum leaks and loss of speed signal to ecu (i.e. ecu doesn't know that it should switch from overrun to idle).
This is my first thought to.
Bubba, why dont you suggest putting in 30bottom end....its your solution for everything else. :D
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
